[Mapserver-users] php mapscript installation problem
Paul Spencer
spencer at dmsolutions.ca
Fri Apr 25 13:07:58 EDT 2003
you will receive this error message when the php_mapscript dll cannot be
loaded because of a missing dependency. You can find out what
dependencies are missing by using depends.exe which, if you don't have
it on your machine by default (it is on winXP by default, not sure about
2000), you can get it from www.dependencywalker.com. Run the
application and open php_mapscript_36.dll, it will tell you exactly what
is missing. The files that it says are missing are all dll files that
need to be in the path somewhere, normally c:\winnt\system32.
Cheers,
Paul
Hurtubise, Yvette wrote:
> Here is my problem...
> I have php (version 4.2.2) installed on Windows2000 and I have tested it, working fine. I'm currently using MapServer 3.6.3.
> I have then places php_mapscript_36.dll into C:\php\extentions\
> and I have also changed my php.ini file so that extenstion_dir = path above.
> My problem occurs when I run this (test.php)...
> <HTML>
> <BODY>
> <?php
> if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
> dl("php_mapscript_36.dll");
> else
> dl("php_mapscript.so");
> phpinfo();
> </BODY>
> </HTML>
> I get the error : Warning: Unable to load dynamic library 'C:\php\extensions\php_mapscript_36.dll' - The specified module could not be found. in c:\inetpub\wwwroot\chilliwack\test.php on line 9<!--
> a { text-decoration: none; }
> a:hover { text-decoration: underline; }
> h1 { font-family: arial, helvetica, sans-serif; font-size: 18pt; font-weight: bold;}
> h2 { font-family: arial, helvetica, sans-serif; font-size: 14pt; font-weight: bold;}
> body, td { font-family: arial, helvetica, sans-serif; font-size: 10pt; }
> th { font-family: arial, helvetica, sans-serif; font-size: 11pt; font-weight: bold; }
> Then is continues to list out a bunch of information.
> I have double check and triple check to make sure that php_mapscript_36.dll is in C:\php\extention\
> Can anyone please help me figure out where I'm going wrong?
> Thanks
> Yvette
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
