AW: [Mapserver-users] limitation to the first 65536 records ofa dbase file ?
Nicole Bömeke
bon at ivv-aachen.de
Sat Apr 26 04:53:08 EDT 2003
Hi Steve,
I'm sorry, but I thing I misjudged the problem.
The error has nothing to do with a limitation of the number of records
in a dbase file. It occures because of the limitation of the CGI GET
Method. I thing the string with the query filter I pass to the mapserver
is too long. Therefore CGI cuts it after 2084(?) characters. Is there
a possibility to pass the query filter to the mapserver using the CGI
POST Method?
Nicole
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Steve
Lime
Gesendet: Freitag, 25. April 2003 23:20
An: bon at ivv-aachen.de; Mapserver-users at lists.gis.umn.edu
Betreff: Re: [Mapserver-users] limitation to the first 65536 records ofa
dbase file ?
We'd need sample data for this one. The query mechanism uses the exact
same feature access code as the draw mechanism. Does the layer draw
ok?
>>> Nicole Bömeke <bon at ivv-aachen.de> 04/24/03 06:27AM >>>
Hi list,
I'm trying to mark a shape in my map that has a record number grater
than
65536 in my dbase file.
But I receive the message "msQueryByAttributes(): Search returned no
results. No matching record(s) found."
It seems that the mapserver can handel only the first 65536 records of
a
dbase file.
Is there a way to avoid this limitation? If not, is it possible to
create a
work around
by starting several querys over different layers at the same time?
Thanks in advance!
Nicole
Ingenieurgruppe IVV
Nicole Bömeke
Oppenhoffallee 171
52066 Aachen
Tel.: 0241-94691-76
Fax.: 0241-531622
e-mail: BON at IVV-Aachen.de
http://www.ivv-aachen.de
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
