[Mapserver-users] installation
sanjay tiwary sanjaykumartiwary44 at yahoo.co.in
Sun Apr 27 09:15:22 EDT 2003
--0-1843227509-1051449322=:50850
Content-Type: multipart/alternative; boundary="0-1847913490-1051449322=:50850"
--0-1847913490-1051449322=:50850
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
Hello       Thanx for support . My problem still continues now with ./mapserv command. I have attahced here a txt file containing the screen shot.Please provide a helping hand.                                          Thax Sanjay
Catch all the cricket action. Download Yahoo! Score tracker
Content-Type: text/html; charset=iso-8859-1
<DIV>
<DIV>
<DIV>Hello</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Thanx for support . My problem still continues now with ./mapserv command. I have attahced here a txt file containing the screen shot.</DIV>
<DIV>Please provide a helping hand.</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Thax Sanjay</DIV></DIV></DIV><p><img src="http://sg.yimg.com/i/aa/icons/28/cricket.gif" height=28 width=28>
Catch all the cricket action. Download <a href="http://in.sports.yahoo.com/cricket/tracker.html" target="_blank">
Yahoo! Score tracker</a>
--0-1847913490-1051449322=:50850--
Content-Type: text/plain; name="screen.txt"
Content-Description: screen.txt
Content-Disposition: inline; filename="screen.txt"
[root at cgg141 root]# ./configure --with-gd --with-tiff  --with-proj  --with-gdal  --with-curl
-bash: ./configure: No such file or directory
[root at cgg141 root]# cd mapserver-3.6.5
[root at cgg141 mapserver-3.6.5]# ./configure --with-gd --with-tiff  --with-proj  --with-gdal  --with-curl
creating cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... flex
checking for yywrap in -lfl... yes
checking for bison... bison -y
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
checking which version of GD to use...
        using libgd from system libs.
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... yes
        using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
        using libpng from system libs.
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageString16 in -lgd... yes
checking for gdImageGifPtr in -lgd... no
        using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from system libs.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
        libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
        using libtiff from system libs.
checking whether we should include EPPL7 support...
        including EPPL7 support.
checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
        using PROJ.4 from system libs.
checking whether we should include thread safe support...
        thread safe support disabled.
checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
        MPATROL support not requested.
checking whether we should include OGR support...
        OGR support not requested.
checking if GDAL support requested... yes
checking for gdal-config... /usr/local/bin/gdal-config
checking if PostGIS support requested... no
checking if OracleSpatial support requested... no
checking whether we should include WMS support...
        OGC WMS compatibility enabled (-DUSE_WMS).
checking whether we should include WMS Client Connections support...
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
        PHP/MapScript module not configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
cc1: warning:   as it has already been specified as a non-system directory
cc1: warning: changing search order for system directory "/usr/include"
mapprimitive.c: In function `msImageCartographicPolyline':
mapprimitive.c:1102: warning: unused variable `intersect_points'
mapprimitive.c:1099: warning: `last_angle' might be used uninitialized in this function
/usr/include/bits/mathinline.h: At top level:
mapprimitive.c:771: warning: `get_centroid' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapproject.c -o mapproject.o
cc1: warning: changing search order for system directory "/usr/local/include"
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapraster.c -o mapraster.o
mapraster.c:978: warning: `drawGIF' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapsde.c -o mapsde.o
c++ -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapogr.cpp -o mapogr.o
cc1plus: warning: changing search order for system directory "/usr/local/include"
cc1plus: warning:   as it has already been specified as a non-system directory
cc1plus: warning: changing search order for system directory "/usr/include"
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mappostgis.c -o mappostgis.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    maplayer.c -o maplayer.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapresample.c -o mapresample.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapwms.c -o mapwms.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapwmslayer.c -o mapwmslayer.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    maporaclespatial.c -o maporaclespatial.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapgml.c -o mapgml.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapprojhack.c -o mapprojhack.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapthread.c -o mapthread.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    epplib.c -o epplib.o
ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o epplib.o
ranlib libmap.a
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shp2img.c -o shp2img.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o shp2img
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shp2pdf.c -o shp2pdf.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shp2pdf.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o shp2pdf
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    legend.c -o legend.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    legend.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o legend
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapserv.c -o mapserv.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    cgiutil.c -o cgiutil.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    mapserv.o cgiutil.o   -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o mapserv
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptree.c -o shptree.o
shptree.c: In function `main':
shptree.c:40: warning: `byte_order' might be used uninitialized in this function
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptree.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o shptree
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptreevis.c -o shptreevis.o
shptreevis.c: In function `main':
shptreevis.c:74: warning: unused variable `pabyBuf'
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptreevis.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o shptreevis
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptreetst.c -o shptreetst.o
shptreetst.c: In function `main':
shptreetst.c:66: warning: `node' might be used uninitialized in this function
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    shptreetst.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o shptreetst
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    scalebar.c -o scalebar.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    scalebar.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o scalebar
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    sortshp.c -o sortshp.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    sortshp.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o sortshp
touch perlvars
pwd > perlvars
echo -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H  -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT   -DUSE_GDAL >> perlvars
echo -I.  -I/usr/include      -I/usr/local/include >> perlvars
echo  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm >> perlvars
echo   >> perlvars
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    tile4ms.c -o tile4ms.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS   -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT    -DUSE_GDAL    -I/usr/include          -I/usr/local/include    tile4ms.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg    -L/usr/local/lib -lgdal.1.1      -lm   -o tile4ms
[root at cgg141 mapserver-3.6.5]# ls -al mapserv
-rwxr-xr-x    1 root     root       475900 Apr 27 18:35 mapserv
[root at cgg141 mapserver-3.6.5]# ./mapserv
./mapserv: error while loading shared libraries: libproj.so.0: cannot open shared object file: No such file or directory
--0-1843227509-1051449322=:50850--
