[Mapserver-users] Re: [maplab-users] Tutorial Raster Layer Using maplab-2.0-dev20030422 Not
rendering
John Norton
jnorton at fs.fed.us
Wed Apr 23 14:18:49 EDT 2003
I just replaced mapscript 37 with mapscript 36. Should I use a different
one? Maplab Info shows...
MapServer version 3.6.6-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Still no raster layer rendered. Is there a file size limit? This tiff is
about 250MB.
John Norton
USDA-RSAC
2222 W 2300 S
Salt Lake City, UT 84119
Phone: 801-975-3766
Fax: 801-975-3478
Intranet: fsweb.rsac.fs.fed.us
Internet: www.fs.fed.us/eng/rsac/
| | Paul Spencer |
| | <pagameba at magma.|
| | ca> |
| | 04/23/2003 11:40|
| | AM |
| | Please respond |
| | to spencer |
| To: John Norton <jnorton at fs.fed.us> |
| cc: maplab-users at dmsolutions.ca, Mapserver Users <Mapserver-users at lists.gis.umn.edu> |
| Subject: Re: [maplab-users] Tutorial Raster Layer Using maplab-2.0-dev20030422 Not rendering |
John,
a couple of things. First, maplab is not yet compatible with mapserver
37 so I am going to assume (hope) that the rendering issues are related
to that.
The other questions are more applicable to the mapserver-users mailing
list so I have copied it on this reply. I would imagine that Frank
Warmerdam wrote the piece in the RASTER-HOW-TO since he is the GDAL
maintainer.
Cheers,
Paul
John Norton wrote:
> After installing maplab-2.0-dev20030422 and running the tutorial project
I
> could not get the bath_mapserver.tif layer to render. I noticed that
> INPUT=TIFF is not compiled into mapscript_37 so I went and built a
> tileindex shapefile and then that raster layer rendered with the map.
> Great! But, now I want to build my own map with a RASTER layer. My raster
> file looks like this:
> Driver: GTiff/GeoTIFF
> Size is 11453, 8504
> Coordinate System is `'
> Origin = (-5791247.097672,6903854.269482)
> Pixel Size = (1000.000000,-1000.000000)
> Metadata:
> TIFFTAG_SOFTWARE=Arc/Info
> Corner Coordinates:
> Upper Left (-5791247.098, 6903854.269)
> Lower Left (-5791247.098,-1600145.731)
> Upper Right ( 5661752.902, 6903854.269)
> Lower Right ( 5661752.902,-1600145.731)
> Center ( -64747.098, 2651854.269)
> Band 1 Block=11453x1 Type=Byte, ColorInterp=Red
> Min=0.000/0, Max=255.000/0, Computed Min/Max=0.000,250.000
> Band 2 Block=11453x1 Type=Byte, ColorInterp=Green
> Band 3 Block=11453x1 Type=Byte, ColorInterp=Blue
> World File is:
> 1000.00000000000000
> 0.00000000000000
> 0.00000000000000
> -1000.00000000000000
> -5791247.09767184130000
> 6903854.26948160120000
> I ran gdaltindex on this tiff file and got the tile shape file and
> installed it into my map file just as I did with the tutorial image. Just
> one tile (for now). The raster layer does not render at all! My map file
is
> using this for EXTENT -5791247.098 -1600145.731 5661752.902 6903854.269.
> First thing I check for such problems. Maplab does not generate any
errors.
> This is my first time using INPUT=GDAL with Mapscript. I have used
GeoTiffs
> quite a bit with the mapserv CGI and have had no problems. In fact I
loaded
> some of those .map files into maplab and I could not get the raster
layers
> to render either. I have looked under every rock, I think, on the docs,
> especially the RASTER-HOW-TO. I would imagine whoever wrote this...
> Eventually I should add some general information on how to
> preprocess raster data for optimal use in MapServer, and give
> specific information on how to use GDAL's rgb2pct.py, gdaladdo and
> gdal_translate to converting stuff into pseudocolored, tiled GeoTIFF
> files with overviews.
> Probably has some incite for this. I am running Windoze 2K with Apache 2.
> Can anyone make suggestions on:
> 1. Why is my raster layer not rendering?
> 2. How can I break a large GeoTiff with wld file into smaller ones with
wld
> files? Are the wld files required?
> 3. How can I build a colormap into a GeoTiff to improve performance?
> Cheers
> John Norton
> USDA-RSAC
> 2222 W 2300 S
> Phone: 801-975-3766
> Fax: 801-975-3478
> Maplab-users mailing list
> Maplab-users at dmsolutions.ca
> http://lists.dmsolutions.ca/mailman/listinfo/maplab-users
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
