[Mapserver-users] classifying raster maps with more than 50 classes
Jan Hartmann jhart at frw.uva.nl
Tue Apr 29 08:55:17 EDT 2003
Hello list,
I'm trying to display some world gridded data (elevation, population,
satellite) with user defined color ramps. All data are resampled to
GeoTiff rasters with 256 values and a colormap. The colors are adequate
for initial display, but I would like to give the user the option to
choose between different predefined color maps (greyscale, equalized,
different color panels). In Grass this is very simple: just adapt the
color table. With MapServer I am able to create classes for the colors I
need, but this is limited to a total of 50 and I have the impression
that evaluating so many class-expressions is not very fast. Is there a
possibility to adapt the colormap in a GDAL file directly before
rendering it? It doesn't have to be within MapServer; a command line
utility would be usable too.  I just don't want to duplicate the raster
file for every color scheme I need.
Jan
Frank Warmerdam wrote:
>>> Jan,
>>> The SCALE=AUTO is done independently for each tile, and so it is
>>> likely that
>>> different scaling ranges would be selected.
>> Is this desirable? I can't see any use for tiled maps with differently
>> scaled tiles. Would it be very difficult to scale from the minimum and
>> maximum values of all displayed tiles combined?
> Jan,
> The desirable thing would be for AUTO scaling to always be based on the
> whole image set for the input layer.  But it is not practical to recompute
> that each time a map is rendered, so the code currently just computes the
> auto-scaling on the basis of the window of imagery actually loaded to
> render the map.
> This means that the scaling changes tile by tile in a tiled layer, and even
> that it it varies from render to render as you zoom in on a single
> raster file.
> The solution isn't to do more work each time the map is rendered, but
> instead
> to have map generation tools that can collect appropriate scaling
> information
> once in advance.  In the meantime I would strongly encourage you to just
> use "gdalinfo -mm <filename>" to get reasonable scaling ranges and enter
> them into the map file.
> The short answer is, it would be very compute intensive (and a quite a bit
> of work to implement for that matter) to have auto raster scaling done on
> the basis of all displayed tiles combined.
> Best regards,
