[Mapserver-users] Re: Problem with ECW
Swaminathan, Gayathri
gayathri at ou.edu
Tue Apr 29 10:21:27 EDT 2003
Hi:
You can find the ECW SDK...which has the dlls on earthmapper.com
Thanks,
Gayathri
-----Original Message-----
To: Lista Mapserver-Users
Sent: 4/29/03 3:16 AM
Subject: [Mapserver-users] Re: Problem with ECW
--- In mapserver-users at yahoogroups.com, Frank Warmerdam <warmerdam at p...>
wrote:
> Braulio M. S. wrote:
> > Hi list,
> > I am using archives ecw and I have a problem. When I do Zoom In in
the image arrives a little in which the image becomes black. Which could
be the problem?
> Hi,
> This problem was fixed in the GDAL ECW driver on October 1st, 2002.
If
> you are using the 1.1.8 release of GDAL or later you should have this
fix.
> If you built from source you can check gdal/frmts/ecw/ecwdataset.cpp
to
> ensure it includes revision 1.10.
Thanks for its fast answer. What it happens, is that I am not sure that
GDAL version I am using. I am using Mapserver, Mapscript and ECW already
compiled, downloaded of DMSolutions
"http://www2.dmsolutions.ca/webtools/dl/" file
"mapserver-3.6.6-dev-win32-php4.3.1-libwww.zip". This file has a
ECW_DLL.zip file with the DLL's:
NCScnet.dll
NCSEcw.dll
NCSEcwC.dll
NCSUtil.dll
I use Windows and unfortunately I can't compile in VC++. You could say
to me where I can find these DLL's with the
resolute problem?
Thanks for everything.
Braulio M. S.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
