[Mapserver-users] which ./configure options needed?
Benjamin Thelen
benjamin.thelen at ccgis.de
Tue Apr 29 10:48:05 EDT 2003
Hi Daniel,
Well, I finally succeded, but I have the feeling I am walking on thin ice,
because I am a newbe in unix, umn, pgsql, postgis..:-). Do you think it was
correct, what I did? I couldn't compare the original php-makefile from
php.net to the FreeBSD one, because I don't know how to configure, because
there is no configure-file. So I don't know if there are differences.
Below I've added the mod_php4 Makefile from the FreeBSD Ports-Collection to
this mail. I have deleted the "--with-apxs=${PREFIX}/sbin/apxs" entry in
"CONFIGURE_ARGS=" and reinstalled php.
It is strange, that info.php still shows that php was compiled with
./configure' '--with-apxs=/usr/local/sbin/apxs', but the
umn-map-server-./configure script was successful.
make wasn't successful then, but that'll be a new mail.
Thanks for your help,
Benjamin
New ports collection makefile for: mod_php4
# Date created: Sun May 28 11:31:54 CEST 2000
# Whom: Dirk Froemberg <dirk at FreeBSD.org>
# $FreeBSD: ports/www/mod_php4/Makefile,v 1.187 2003/03/07 06:12:44 ade Exp
PORTNAME= mod_php4
PORTVERSION= 4.3.1
PORTREVISION= 0
CATEGORIES= www
MASTER_SITES= http://us.php.net/${PHP_DISTDIR}/ \
http://php.he.net/${PHP_DISTDIR}/ \
http://www.php3.de/${PHP_DISTDIR}/ \
http://au.php.net/${PHP_DISTDIR}/ \
http://at.php.net/${PHP_DISTDIR}/ \
http://br.php.net/${PHP_DISTDIR}/ \
http://php.easydns.com/${PHP_DISTDIR}/ \
http://www.php.cz/${PHP_DISTDIR}/ \
http://php3.globe.de/${PHP_DISTDIR}/
DISTNAME= php-${PORTVERSION}
MAINTAINER= dirk at FreeBSD.org
COMMENT= PHP4 module for Apache
BUILD_DEPENDS= ${APXS}:${APACHE_PORT}
RUN_DEPENDS= ${APXS}:${APACHE_PORT}
.if defined(WITH_APACHE2)
LIB_DEPENDS= pth.20:${PORTSDIR}/devel/pth
.endif
PHP_DISTDIR= distributions
USE_BZIP2= yes
USE_SUBMAKE= yes
USE_AUTOCONF_VER=213
APACHE_PORT?= ${PORTSDIR}/www/apache2
.else
APACHE_PORT?= ${PORTSDIR}/www/apache13
.endif
APXS?= ${LOCALBASE}/sbin/apxs
.if !defined(BATCH) && !defined(PACKAGE_BUILDING)
IS_INTERACTIVE= yes
.endif
CONFIGURE_ARGS= --with-apxs2=${PREFIX}/sbin/apxs \
--with-tsrm-pth
PLIST_SUB= MOD_DIR=libexec/apache2
.else
CONFIGURE_ARGS= --with-apxs=${PREFIX}/sbin/apxs
.endif
CONFIGURE_ARGS+=--with-config-file-path=${PREFIX}/etc \
--enable-versioning \
--with-regex=system \
--without-gd \
--without-mysql
CFLAGS+= -I${PREFIX}/include
SCRIPTS_ENV= WRKDIRPREFIX="${WRKDIRPREFIX}" \
TOUCH="${TOUCH}" \
MKDIR="${MKDIR}" \
CAT="${CAT}" \
PHP4_OPTIONS="${PHP4_OPTIONS}" \
REALCURDIR="${.CURDIR}"
pre-fetch:
@${SETENV} ${SCRIPTS_ENV} ${SH} ${SCRIPTDIR}/configure.php
.if !defined(WITH_APACHE2)
@${ECHO_CMD} "Define WITH_APACHE2 to build mod_php4 as an apache2 module."
@${ECHO_CMD} ""
.endif
post-install:
@${INSTALL_DATA} ${WRKSRC}/php.ini-dist ${PREFIX}/etc
@${ECHO_CMD}
@${ECHO_CMD} "Make sure the mime.types are connected to the php module
properly and"
@${ECHO_CMD} "index.php is part of your DirectoryIndex."
@${ECHO_CMD} ""
@${ECHO_CMD} "The following should be in your Apache configuration file:"
@${ECHO_CMD} "[...]"
@${ECHO_CMD} "DirectoryIndex index.php index.html"
@${ECHO_CMD} "AddType application/x-httpd-php .php"
@${ECHO_CMD} "AddType application/x-httpd-php-source .phps"
@${ECHO_CMD}
post-clean:
@${RM} -f ${WRKDIRPREFIX}${.CURDIR}/Makefile.inc
.if exists(${WRKDIRPREFIX}${.CURDIR}/Makefile.inc)
.include "${WRKDIRPREFIX}${.CURDIR}/Makefile.inc"
.endif
# XXX:
# Has to be kept in sync with the defaults in configure.php
.ifndef(WITHOUT_MYSQL)
.ifmake describe
LIB_DEPENDS+= mysqlclient.10:${PORTSDIR}/databases/mysql323-client
.endif
.endif
.include <bsd.port.mk>
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Friday, April 25, 2003 6:08 PM
> To: Benjamin Thelen
> Cc: UMN MapServer
> Subject: Re: [Mapserver-users] which ./configure options needed?
> Benjamin Thelen wrote:
> > Hi again,
> > I could find out with which options php was compiled:
> > '--with-config-file-path=/usr/local/etc' '--enable-versioning'
> > '--with-regex=system' '--without-gd' '--without-mysql'
> > '--with-gd=/usr/local' '--enable-gd-native-ttf'
> > '--with-freetype-dir=/usr/local' '--with-jpeg-dir=/usr/local'
> > '--with-png-dir=/usr/local' '--with-zlib' '--with-pdflib=/usr/local'
> > '--with-zlib-dir=/usr' '--with-jpeg-dir=/usr/local'
> > '--with-png-dir=/usr/local' '--with-tiff-dir=/usr/local'
> > '--with-mysql=/usr/local' '--with-pgsql=/usr/local' '--with-dbase'
> > '--with-expat-dir=/usr/local' '--with-dom=/usr/local'
> '--prefix=/usr/local'
> > 'i386-portbld-freebsd4.7'
> > So, as you can see, it was compiled with regex=system.
> > What can I do now??
> --with-regex=system has no effect when you use --with-apxs. ANyway you
> need PHP compiled as a CGI so you should remove the --with-apxs config
> option, and then --with-regex=system will also start to work.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
