[Mapserver-users] Compiling stops: cannto find -lPDF
Steve Lime
steve.lime at dnr.state.mn.us
Tue Apr 29 18:00:23 EDT 2003
Is your shared library setup correct. Check out /etc/ld.so.conf and the
command ldconfig.
Steve
>>> R00T <r000t at adelphia.net> 04/29/03 10:04AM >>>
I seem to be having a problem with shp2img myself on RedHat 9.......
-jim
On Tue, 2003-04-29 at 10:48, Benjamin Thelen wrote:
> Hi,
> after finally ./configure was successful, make stops. Please see
below:
> root at qwertzuiop# make
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API
> _H -DUSE_WMS -DUSE_WMS_LYR -DUSE_TIFF -DUSE_JPEG -DUSE_GD_GIF
-DUSE_GD_PNG
> -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR
-DUSE_PDF -
> DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -I/usr/local/include
-I/usr/local/incl
> ude -I/usr/local/include -I/usr/local/include
> usr/local/include -I/usr/local/include -I/usr/local/include
-I/usr/local/in
> clude/w3c-libwww -DHAVE_CONFIG_H
> shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -L/usr/local/lib
-ljpeg -L/u
> sr/local/lib -lfreetype -lz -L/usr/local/lib -lpng -lz
-L/usr/local/lib -lPD
> F -ltiff -L/usr/local/lib -ljpeg -L/usr/local/lib -lfreetype -lz
-L/usr/loca
> l/lib -lpng -lz -L/usr/local/lib -lproj -L/usr/local/lib -ljpeg
-L/usr/lo
> cal/lib -lgdal.1.1 -L/usr/local/lib -lpq -L/usr/local/lib -lwwwxml
-lxmlto
> k -lxmlparse -lwwwzip -lwwwinit -lwwwapp -lwwwhtml -lwwwtelnet
-lwwwnews -lw
> wwhttp -lwwwmime -lwwwgopher -lwwwftp -lwwwfile -lwwwdir -lwwwcache
-lwwwstr
> eam -lwwwmux -lwwwtrans -lwwwcore -lwwwutils -lmd5 -lz -lm -o
shp2img
> /usr/libexec/elf/ld: cannot find -lPDF
> *** Error code 1
> Stop in /tmp/downloaded/mapserver-3.6.5.
> I don't understand, why make cannot find lPDF, because of this
(excerpt from
> configure-output):
> checking whether we should include PDF support...
> using libpdf from -L/usr/local/lib -lPDF.
> This seems to be quite obvious no error. The complete
configure-output is
> below. I have installed libPDF 4.x and libPDF 5.0.0. Is it one to
much?
> Has anybody an idea?
> Thanks,
> Benjamin
> ./configure --with-gd --with-gdal --with-ogr --with-proj=/usr/local
--with-j
> peg=/usr/local --with-pdf=/usr/local --with-png=/usr/local
--with-zlib --wit
> h-freetype --with-php=/usr/ports/www/mod_php4/work/php-4.3.1
--with-wmsclien
> t --with-postgis --enable-runpat
> loading cache ./config.cache
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for c++... (cached) c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... no
> checking whether we are using GNU C++... (cached) yes
> checking whether c++ accepts -g... (cached) yes
> checking for ranlib... (cached) ranlib
> checking for flex... (cached) flex
> checking for yywrap in -lfl... (cached) yes
> checking for bison... (cached) bison -y
> checking if compiler supports -R... (cached) yes
> checking for exp in -lm... (cached) yes
> checking how to run the C preprocessor... (cached) gcc -E
> checking for ANSI C header files... (cached) yes
> checking for strcasecmp... (cached) yes
> checking for strncasecmp... (cached) yes
> checking for strdup... (cached) yes
> checking whether we should include JPEG support...
> using libjpeg from system -L/usr/local/lib -ljpeg
> checking which version of GD to use...
> using libgd from system libs.
> checking where FreeType is installed...
> checking for freetype-config... (cached)
/usr/local/bin/freetype-config
> using libfreetype from -L/usr/local/lib -lfreetype -lz
> checking for FT_Init_FreeType in -lfreetype... no
> checking for TT_Init_FreeType in -lttf... no
> using libfreetype -L/usr/local/lib -lfreetype -lz from system
libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> checking where PNG is installed...
> using libpng from -L/usr/local/lib -lpng
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... yes
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageString16 in -lgd... yes
> checking for gdImageGifPtr in -lgd... yes
> using GD
> ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
-DGD_HAS
> _GDIMAGEGIFPTR) from system libs.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
> using libtiff from system libs.
> checking whether we should include EPPL7 support...
> including EPPL7 support.
> checking whether we should include PROJ.4 support...
> checking for pj_transform in -lproj... yes
> checking for pj_latlong_from_proj in -lproj... yes
> using PROJ.4 from /usr/local.
> checking whether we should include thread safe support...
> thread safe support disabled.
> checking whether we should include ESRI SDE support...
> ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
> MPATROL support not requested.
> checking whether we should include OGR support...
> checking for gdal-config... (cached) /usr/local/bin/gdal-config
> checking for OGRRegisterAll in -lgdal.1.1... (cached) yes
> using OGR from system libs.
> checking if GDAL support requested... yes
> checking if PostGIS support requested... yes
> checking for pg_config... (cached) /usr/local/bin/pg_config
> yes, user supplied pg_config
> checking if OracleSpatial support requested... no
> checking whether we should include WMS support...
> OGC WMS compatibility enabled (-DUSE_WMS).
> checking whether we should include WMS Client Connections support...
> checking for libwww-config... (cached) /usr/local/bin/libwww-config
> found libwww version 5.4.0
> OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
> checking for potential conflict between system regex and rxposix...
> checking for regexec in -lrx... (cached) no
> Compiling with -DIGNORE_MISSING_DATA.
> checking whether we should enable debug features...
> checking for PHP/MapScript module options...
> checking whether 'perl -V' works... yes
> checking for location of config.h or php_config.h...
> /usr/ports/www/mod_php4/work/php-4.3.1/main/php_config.h
> checking whether we have PHP3 or PHP4... -DPHP4
> checking whether we should use PHP's regex... no
> PHP/MapScript module configured.
> updating cache ./config.cache
> creating ./config.status
> creating Makefile
> creating mapscript/php3/Makefile
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
