[Mapserver-users] World file
Wed Apr 30 11:18:57 EDT 2003
Marco Ferrari wrote:
> Hi,
> I use MapServer on windows XP:
> MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORT
> S=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OG
> R INPUT=GDAL INPUT=SHAPEFILE
> (and I try to use another mapserver version with libtiff on windows xp and 2000, too) but I had
> always the same problem with the file ".tif".
> I must display ".tif" with ".tfw". These files are all in the same directory "data" with the shapefile
> and their name are D5A1.tif D5A1.tfw and D5A2.tif D5A2.tfw
> My problem is that mapserver displays my ".tif" file but it doesnt'use tfw file for georeference them.
> So it doesn't read tfw file.
> (I tried also to rename tfw to wld, tifw, ...  but the risult is the same.)
Marco,
If the TIFF file has internal coordinates in geotiff format, I think the
.tfw file will be ignored.  You could try "stripping" off the geotiff info
by running the TIFF file through tiffcp (eg. tiffcp orig.tif new.tif) or
loading and saving from an environment like photoshop that ignores geotiff
info.
Best regards,
