[Mapserver-users] Proj problems
Vincent Schut
schut at sarvision.com
Fri Aug 1 09:42:10 EDT 2003
On Friday 01 August 2003 15:17, Gerry Creager N5JXS wrote:
> Vincent Schut wrote:
> > There are a bunch of documents on the internet that say proj=longlat
> > (google for it, you'll be stumped!). I believe they are wrong... However,
> > if it is in the mapserver docs/wiki somewhere, we should track that down
> > and have it corrected.
> I'll try to find the references...
After some research I found longlat even in my postgis.sql, defining the
projection parameters for postgis... I guess that longlat works too, then.
But according to the docs, it should be latlong.
Cheers,
Vincent.
