[Mapserver-users] Re: styleitem
Daniel Morissette
morissette at dmsolutions.ca
Fri Aug 1 10:36:47 EDT 2003
Please use the mapserver-users list for your questions. Others may have
the same problem and learn from the questions/answer when reading the
list or browsing/searching the archives. Plus you increase your chances
of getting a response since more eyes will see your question. And
finally that saves us from having to reply dozens of times to the same
question via direct email.
See reply to your question below...
Jean-Baptiste RICHARD wrote:
> hi, i'm sorry to ask you this question but i don't understand one thing
> using styleitem "auto".
> The color of my .tab file are rendered, but i can't access a legend icon
> for each class.
> I read that it is a bug with mapserver 4.0, but could i make appear the
> legend icon if i only take one class (expression = '1' for instance)?
> In every case, my legend is empty and it seems to be a bit complicated
> if i have to make a nex legend for each layer .tab and colored in
> mapinfo.
> Thanks for your help and sorry for my bad english,
> RICHARD Jean-Baptiste
Even if you set the style/color of class #1 in your layer it will be
overwritten by the styleitem auto stuff and you won't get the expected
legend icons.
But there's hope... a new KEYIMAGE class-level parameter has been added
in 4.0 but haven't tried yet, that should allow you to specify the image
to use for the legend icon. There was an email sent about this on the
list by Steve on July 29 but I don't see it in the list archives, I have
attached a copy below.
BTW, KEYIMAGE isn't documented in the mapfile reference docs either...
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Steve Lime wrote:
> There is a new CLASS level parameter in 4.0 called KEYIMAGE that allows
> you to
> specify the legend image to use when building a legend (or requesting a
> legend
> icon via MapScript or the CGI application). You can see it in action
> at:
> http://maps.dnr.state.mn.us/mapserver_demos/workshop/
> Turn on the DOQ layer and you'll see the KEYIMAGE in the legend. Note
> the the
> KEYIMAGE is sized to fit within the key specifications defined in the
> LEGEND section.
> Steve
