[Mapserver-users] Double labeling in querymap?
Daniel Morissette morissette at dmsolutions.ca
Mon Aug 4 22:34:48 EDT 2003
I noticed the same before and believe this is a bug that was present in
3.6 too.  To make sure we don't forget I have filed it in bugzilla.
Please add yourself to the CC of the bug if you want to be notified when
we work on it:
  http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=396
Daniel
Fawcett, David wrote:
> This occurs when the STYLE property of the QUERYMAP object is set to HILITE, but does not occurr when I change it to SELECTED.
> David.
>>From: 	Fawcett, David[SMTP:David.Fawcett at state.mn.us]
>>Sent: 	Monday, August 04, 2003 4:27 PM
>>To: 	'mapserver-users at lists.gis.umn.edu'
>>Subject: 	[Mapserver-users] Double labeling in querymap?
>>I am not sure if this is a bug or PIBCAK*
>>Version 4.0 beta2 (7/11/03)
>>When I query a point feature, the querymap puts two identical labels on the selected point feature, but correctly places only one label on the other point features on the map.
>>The point layer only exists once in the MAP file, so I am not querying two overlaying instances of the same point.
>>Am I getting a cached label showing up?  I really only need to label each facility once.
>>Thanks,
>>David.
>>David Fawcett
>>MN Office of Environmental Assistance
>>*Problem Is Between Chair and Keyboard
