[Mapserver-users] Problem w/ 8-bit TIF & Mapserver 3.3
mp28
mp28 at humboldt.edu
Tue Aug 5 20:58:30 EDT 2003
Hello,
I've been working on getting mapserver to render a set of high-resolution
aerial photos. The images are in .tif format, unsigned 8-bit with an
associated .tfw file. We are currently using Mapserver v3.3. For testing
purposes we are trying to get just a single image to work but here is the
problem.... Mapserver doesn't return an image (in map mode) when the layer is
added. Here is the mapfile entry ->
LAYER # Aerial test
NAME "aerial"
DATA ./aerial/nov01_utm/rm94g_wv.tif
STATUS OFF
TYPE RASTER
END
The file size of the test photo is 15.4 MB which shouldn't be a problem since
we're successfully using a 30 MB tif w/ mapserver. The paths are correct
(other tifs in the same directory work). The image is 8-bit and displays
perfectly in other GIS/RS software.
Is there any thing I'm forgetting? Is there some minor variation in the .tif
format that could be causing this? Has anyone run into this before??
I'll have access to the mapserver error log tomorrow... is there anything I
should look for?
Thanks for the help, guys.
Matthew Perry
Humboldt State University
Environmental and Natural Resource Sciences
http://ktrin.cnrs.humboldt.edu
