[Mapserver-users] Error installing MapServer
Vincent Schut
schut at sarvision.com
Tue Aug 5 10:57:20 EDT 2003
I'm sorry to say but I don't think so...
You should really get the message "No query information to
> decode. QUERY_STRING is set, but empty." in your browser. Mapserver should
generate the right headers.
What is the output if you just try to run mapserv.exe on the command line
(sorry for this linux talk, I mean in a dos window ;-))?
I'm not a mapserver-on-windows guru as I do everything on linux, so I may be
wrong. But I think you really should get the normal message. If I'm wrong
however, could one of the windows-folks correct me?
Cheers,
Vincent.
On Tuesday 05 August 2003 16:13, Swaminathan, Gayathri wrote:
> Cool Marvin!
> You have successfully set up your mapserver.
> This,
> "I got the error "CGI Error
> The specified CGI application misbehaved by not returning a complete set of
> HTTP headers. The headers it did return are:" And no header is shown at
> all.
> I read that I have to get the following: No query information to
> is not an error message. It is supposed to do this. For more information
> search the list archive on your error., this is an acceptable response.
> You should now follow the steps in the demo package, to set up mapserver
> mapfile/templates to get all cooking.
> Thanks,
> Gayathri
> -----Original Message-----
> From: Mario Servin [mailto:mservin at tecnoaccion.com.ar]
> Sent: Tuesday, August 05, 2003 9:14 AM
> To: Swaminathan, Gayathri
> Subject: Re: [Mapserver-users] Error installing MapServer
> Dear Gayathri,
> Thanks for your answer. I followed your advise and got the LIBPQ.dll
> from PostGis. This solved the "not found" message but still when I use a
> browser to see some answer from MapServer, i.e. trying to browse
> http://localhost/Scripts/mapserv.exe" I got the error "CGI Error
> all.
> Regards,
> Mario
> ----- Original Message -----
> From: Swaminathan, <mailto:gayathri at ou.edu> Gayathri
> To: 'Mario Servin' <mailto:mservin at tecnoaccion.com.ar> ;
> mapserver-users at lists.gis.umn.edu
> <mailto:mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, August 05, 2003 10:47 AM
> Subject: RE: [Mapserver-users] Error installing MapServer
> Hi Marvin:
> The mapserver you downloaded has Postgres included and requires this dll,
> "LIBPQ.dll" and hence the error (7).
> You can find it at ,
> http://postgis.refractions.net/download.php
> <http://postgis.refractions.net/download.php> as, libpq.zip Unzip
> contents, copy the libpoq.dll to your windows system directory and register
> it.
> HTH,
> Gayathri
> Sent: Tuesday, August 05, 2003 8:41 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Error installing MapServer
> Hi all,
> I am having errors with the installation of MapServer 4.0. I followed
> the steps:
> 1-Downloaded the binary MapServer 4.0 for Windows. My platform is Windows
> XP with IIS 5.0.
> 2-Extract the files to C:\Documents and Settings\mario\MyInstall\MapServer
> 3-Copy \Proj to C:\Proj
> 4-Add C:\Documents and Settings\mario\MyInstall\MapServer\lib to the path
> variable of my Windows.
> 5-Create the virtual directory Scripts of my Default Web Site because it
> was not created. I pointed it to the folder IIS C:\Inetpub\Scripts.
> 6-Copy mapserv.exe to C:\Inetpub\Scripts.
> 7-Opened a command prompt window in C:\Inetpub\Scripts and typed:
> mapserv.exe. I got the following error: "This application failed to start
> because LIBPQ.dll was not found. Re-installing the application may fix this
> problem."
> 8-tried to execute from the browser and get the following error: "CGI Error
> all.
> Can anybody help me on how to proceed to get a correct installation?.
> Regards,
> Mario
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
