[Mapserver-users] Fw: Error installing MapServer
Mario Servin
mservin at tecnoaccion.com.ar
Wed Aug 6 14:50:50 EDT 2003
Dear Ed,
There were some touches on the folder path I had to adjust but finally I
have the demo_init.html working, or so. I can see the map,etc. Now there is
something weird when I try to make a refresh or zoom or anything else that
goes after, again I got the : "msLoadMap(): Unable to access file.
(C:\Documents and Settings\mario\MyPages\itasca\demo.map)"!. I am checking
the submitted string to see what happening but I am pretty sure it's again a
matter of paths.....
Regards,
Mario
----- Original Message -----
To: "Mario Servin" <mservin at tecnoaccion.com.ar>; "Howard Mark"
<MHoward at spaceimaging.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, August 06, 2003 2:45 PM
Subject: RE: [Mapserver-users] Fw: Error installing MapServer
> Mario -
> Remember that MapServer is running under the user context of (usually) the
anonymous Web user, which is by default set to IUSR_machinename. You need
to make sure that (a) that path is in fact where the demo.map file is, and
(b) that the IUSR_machinename account has permission to read that file.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Mario Servin [mailto:mservin at tecnoaccion.com.ar]
> Sent: Wednesday, August 06, 2003 12:53 PM
> To: Howard Mark
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Fw: Error installing MapServer
> Dear Mark,
> You have the magic powers of Gandalf or you were dealing with IIS a
> lot...., you are absolutely right!!!.
> That works!, Now I got "No query information to decode. QUERY_STRING
not
> set. " . When I run the MapServer demo still I got the following
> "msLoadMap(): Unable to access file. (C:\Documents and
> Settings\mario\MyPages\itasca\demo.map)" but I think it is a minor problem
> that I have to deal with, maybe there is something related to spaces in
the
> folder names.
> Thanks a lot an best regards,
> Mario
> From: "Howard Mark" <MHoward at spaceimaging.com>
> To: "'Mario Servin'" <mservin at tecnoaccion.com.ar>
> Sent: Wednesday, August 06, 2003 1:32 PM
> > Mario,
> > You might try copying all the dll's ..... to a folder that is on
> everyone's
> > path such as c:\winnt\system32.
> > IIS runs under it's own user and may not be able to see the programs.
> > Just a though.
> > Mark
> > Sent: Wednesday, August 06, 2003 9:38 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Fw: Error installing MapServer
> > From: "Mario Servin" <mservin at tecnoaccion.com.ar>
> > To: "Swaminathan, Gayathri" <gayathri at ou.edu>
> > Cc: <mailto:mapserver-users at lists.gis.umn.edu>
> > Sent: Wednesday, August 06, 2003 12:06 PM
> > Subject: Re: Error installing MapServer
> > > Dear Gayathri,
> > > I am a bit of giving up with this!. Finally I could retreive a map
> but
> > > only from a command prompt console:
> > > C:\Program Files\MapServer>mapserv "QUERY_STRING=map=c:\Documents and
> > > Settings\mario\MyPages\itasca\demo.map&mode=map"
> > > That gave a map and told me :
> > > Content-type: image/gif
> > > GIF87a ....and all the meaningless characters that correspond to the
> image
> > > follow.
> > > But, but, FROM the browser there is a big problem!!. I checked the
> > logs
> > > of my WebServer and find a 502 code that means "bad gateway" that does
> not
> > > tell me nothing. I suspect that my IIS configuration does not allow
the
> > > execution of any cgi executable. I am now investigating why this can
> > happen.
> > This message is intended only for the use of the Addressee and may
> > contain information that is PRIVILEGED and CONFIDENTIAL.
> > If you are not the intended recipient, you are hereby notified that any
> > dissemination of this communication is strictly prohibited. If you have
> > received this communication in error, please erase all copies of the
> > message and its attachments and notify Space Imaging immediately.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
