[Mapserver-users] 4.0 DATA Keyword / CGI variable
Michael Schulz
mschulz at webgis.de
Thu Aug 7 09:13:37 EDT 2003
the method for changing DATA and TEMPLATE values of the map-file through
CGI has changed, it is now done via a DATAPATTERN regular expression.
Information can be found in the wiki:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide and in the
mentioned posting
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0302/msg00795.html
HTH, Michael
Shannon Scott schrieb:
> Hello,I have a layer ( below ) that is in an Oracle DB. We change the
> DATA parameter "on the fly" ( via CGI variable ) to select and
> highlight the polygon we want to display. This worked very well in
> 3.6, but we are unable to change the DATA parameter since we upgraded
> to 4.0. I can still change other keyword parameters ( for example
> COLOR ).Has anyone else experienced this? Workaround?Any info, or
> advice is greatly appreciated.Thank You.Shannon Apache CGILinux RedHat
> 8.0MN Mapserver 4.0
> LAYER
> NAME selectedpoly
> TYPE Polygon
> STATUS default
> CONNECTIONTYPE oraclespatial
> CONNECTION "xxx/xxx at locinc9"
> TRANSPARENCY 50 DATA "GEOM from (select a.GEOM from tracts1 a
> where a.id=23019000100)"
> CLASS
> NAME "selectedpolyclass"
> COLOR 255 255 191
> OUTLINECOLOR 8 8 8
> END # CLASS
> PROJECTION
> "proj=latlong"
> END
> END # Tracts LAYER
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
