[Mapserver-users] in pursuit of an HDF example
Charlton Purvis
cpurvis at asg.sc.edu
Thu Aug 7 16:18:52 EDT 2003
Hi, folks:
Anybody have an example of a .map incorporating an HDF? Are they
treated the same as regular rasters? I doubt it. But I'm not having
much luck w/ a file that looks like:
$ gdalinfo 030708.1032.n12.hdf
Driver: HDF4Image/HDF4 Dataset
Size is 969, 1558
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 1558.000)
Upper Right ( 969.000, 0.000)
Lower Right ( 969.000, 1558.000)
Center ( 484.500, 779.000)
Band 1 Block=969x1 Type=Byte, ColorInterp=Gray
I've tried a barebones .map w/ extents to match the corner coordinates
listed above, but no dice.
Unfortunately, I don't know enough about HDF to be dangerous, but does
MapServer (or GDAL) pull out georeferencing from the HDF and make a .wld
moot? Or do I still need to create a .wld per HDF? Haven't I also
heard that HDF's are capable of containing multiple rasters?
Thanks for your help.
Charlton
Charlton Purvis
(803) 777-8858 : voice
(803) 777-8833 : fax
cpurvis at sc.edu
Advanced Solutions Group
Department of Physics and Astronomy
University of South Carolina
Columbia, SC 29208
