[Mapserver-users] Compiling GDAL by MinGW
Norman Vine nhv at cape.com
Thu Aug 7 21:52:40 EDT 2003
Hisaji Ono writes:
> ./configure --with-libz=internal --with-png=internal --with-libtiff=internal
> >  --with-geotiff=internal --with-jpeg=internal   .... other configure args
>  I could build GDAL-1.1.8 by above sample.
>  But these build libraries & applications for Cygwin?
>  For compiling, no requires to set flag "-mno-cygwin" for gcc & g++?
Yes,  you need to set the compiler like you did initially
i.e.
CC='gcc -mno-cygwin' CXX='g++ -mno-cygwin' \
./configure --with-libz=internal --with-png=internal --with-libtiff=internal \
 --with-geotiff=internal --with-jpeg=internal  \
 $OTHER_LOCAL_CONFIGURE_OPTIONS
make sure you replace  $OTHER_LOCAL_CONFIGURE_OPTIONS
with your desired options
If you still need further help please ask on the gdal list
HTH
Norman
