[Mapserver-users] Just display a layer (2)
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 8 08:58:47 EDT 2003
harato wrote:
> probably my mapfile is wrong (maybe ?)
> have I need to add projection value ?
> I've attached my mapfile example, if anyone can help
> me...
> LAYER
> NAME "Département"
> STATUS ON
> DATA "./dept56"
> TYPE POLYGON
> UNITS METERS
> SIZEUNITS PIXELS
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> METADATA
> "Description" "Département"
> END
> CLASS
> NAME "dept56"
> EXPRESSION "0"
> SYMBOL 12
> COLOR 153 255 255
> OUTLINECOLOR 51 204 255
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
Harato,
I would suggest turning the layer status to DEFAULT, but the problem I ran
into with this configuration was your use of EXPRESSION "0". If I comment
that out it renders OK for me in MapServer.
I don't see anything indicating what variable is being used for the
classification, so I don't know what the EXPRESSION is testing, but whatever
(if anything it is), it doesn't match your expression.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
