[Mapserver-users] mapserver & win2k
Randy James
rjames57 at yahoo.com
Mon Aug 11 16:41:39 EDT 2003
Hi
If your are getting the template page minus the images,
maybe check your path to your images and/or check if the
images are created. (in your tmp folder)
Hope this helps
Cheers
Randy
--- "Dubnansky, Andrew" <adubnansky at 3eTI.com> wrote:
> I have downloaded & installed ms40_gif_pg.zip &
> ms366_gif_wms.zip (on
> separate win2k machines) .
> I am using win2k and IIS 5.0.
> I have installed everything according to the
> respective "readme" files,
> the only minor exception being that I have put
> mapserv.exe in the
> "scripts" directory in IIS instead "cgi-bin", and:
> (1) Version 4 was missing a file called "libpq.dll" which
> I found on the
> internet and copied to my system directory.
> (2) Version 3.6.6 was missing a file called "zlib.dll"
> which I found on the
> I cannot get the ver. 3.5 demo or the ver. 4.0 demo to
> run at all. The
> "demo_init" webpage will bring up the display page, but
> there are red "x"s
> where the map, legend, and scalebar image should be.
> Typing "mapserv -v" at the command line returns the
> expected responses.
> e.g. - MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I am at a loss to locate what I have missed. I have
> double checked the
> directory struct, capitalization issues, etc.Any help
> would be very
> appreciated.
> thanks in advance,
> - AJ
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
