[Mapserver-users] MapLab error
Geoffrey Rowland
geoffrey.rowland at noaa.gov
Tue Aug 12 17:08:45 EDT 2003
This is a multi-part message in MIME format.
--------------060607050109060308040703
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I just installed MapLab and seem to be having some problems with it. If
I view installation information, it shows everything installed
correctly. However if I try and open the XML Config Utility, it comes
up with the following warnings
Warning: fopen(../config/gmapfactory.xml): failed to open stream:
Permission denied in
D:\wkdir\wnv\maplab\htdocs\common\appcontext\appcontext.php on line 553
Warning: fopen(../config/maplab.xml): failed to open stream: Permission
denied in D:\wkdir\wnv\maplab\htdocs\common\appcontext\appcontext.php on
line 55
and I can't seem to change any of the values. Worst case I suppose I
can just change them manually....I was just wondering if anyone had any
idea as to what was causing this error.
Thanks,
Geoff
Geoffrey Rowland
Technical Officer
Climate Information Project
NOAA Research
Office of Global Programs
http://www.cip.ogp.noaa.gov
Contractor,
RGII Technologies, Inc., a Computer Horizons Company
http://www.rg2.com
Phone: 301-427-2089x186
Fax : 301-427-2082
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
Hi,<br>
<br>
If I view installation information, it shows everything installed
up with the following warnings<br>
<br>
<b>Warning</b>: fopen(../config/gmapfactory.xml): failed to open
stream: Permission denied in <b>D:\wkdir\wnv\maplab\htdocs\common\appcontext\appcontext.php</b>
on line <b>553</b><br>
<br>
<b>Warning</b>: fopen(../config/maplab.xml): failed to open stream:
on line <b>55<br>
<br>
</b>and I can't seem to change any of the values. Worst case I suppose
I can just change them manually....I was just wondering if anyone had
any idea as to what was causing this error.<br>
<br>
Thanks,<br>
Geoff<br>
<br>
<script> function formChanged()
main.bSave.value = 1;
</script>
<form name="main" method="post">
<center>
<table cellspacing="0" cellpadding="1" width="400" bgcolor="#ffffff"
border="0">
<tbody>
<tr>
</tr>
</tbody>
</table>
</center>
</form>
-- <br>
<pre class="moz-signature" cols="72">Geoffrey Rowland
Technical Officer
NOAA Research
<a class="moz-txt-link-freetext" href="http://www.cip.ogp.noaa.gov">http://www.cip.ogp.noaa.gov</a>
Contractor,
<a class="moz-txt-link-freetext" href="http://www.rg2.com">http://www.rg2.com</a>
Fax : 301-427-2082
<a class="moz-txt-link-abbreviated" href="mailto:geoffrey.rowland at noaa.gov">geoffrey.rowland at noaa.gov</a>
</pre>
</body>
</html>
--------------060607050109060308040703--
