[Mapserver-users] line thickness?
Dean Gadoury
gadoury at dmsolutions.ca
Wed Aug 13 15:20:03 EDT 2003
This is a multi-part message in MIME format.
--------------030107070700000603060706
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
You need to use a symbol, preferably a circle, and then use the SIZE
property in your class. Here's an example:
If you don't have a circle symbol in your symbol file use this and put
it in the MAP object
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
Then in your layer object make a class, something like this:
CLASS
NAME "whatever"
STYLE
SYMBOL 'circle'
COLOR 0 0 0
SIZE 3
END
END
That will result in a line 3 pixels wide. Just change the SIZE property
to change the thickness of the line.
Bruce Bushby wrote:
>I've been playing around with Mapserv4.0 for a few days and I can't
>find a way to render 'line thickness' for my ESRI street maps.
>Is it possible to specify 'line thickness' when rendering a layer?
>Thanks for the help
>Regards
>Bruce
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dean Gadoury
DM Solutions Group
72 Chamberlain Ave. Third Floor
Ottawa, Ontario. K1S 1V9
613 565-5056 ext. 24
www.dmsolutions.ca
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
property in your class. Here's an example:<br>
<br>
it in the MAP object<br>
<br>
<font color="#0000ff" size="2">SYMBOL<br>
NAME 'circle'<br>
TYPE ELLIPSE<br>
POINTS 1 1 END<br>
FILLED TRUE<br>
END</font><br>
<br>
Then in your layer object make a class, something like this:<br>
<br>
CLASS <br>
NAME "whatever"<br>
STYLE<br>
SYMBOL 'circle' <br>
COLOR 0 0 0<br>
SIZE 3 <br>
END<br>
END
<br>
<br>
to change the thickness of the line.<br>
<br>
<br>
Bruce Bushby wrote:<br>
<blockquote type="cite"
cite="midAAEIINHPKBPIPAAPNOLJOEBFCBAA.bruce.bushby at wol.co.za">
<pre wrap="">I've been playing around with Mapserv4.0 for a few days and I can't
Thanks for the help
Regards
Bruce
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="72">--
Dean Gadoury
DM Solutions Group
<a class="moz-txt-link-abbreviated" href="mailto:gadoury at dmsolutions.ca">gadoury at dmsolutions.ca</a>
<a class="moz-txt-link-abbreviated" href="http://www.dmsolutions.ca">www.dmsolutions.ca</a></pre>
</body>
</html>
--------------030107070700000603060706--
