[Mapserver-users] help with ???->draw() mapscript function
Matt Doggett
mdoggett at coas.oregonstate.edu
Wed Aug 13 16:44:26 EDT 2003
Your reply helps a lot. Thanks.
I'm still not clear about the difference between the Point->draw() and
the LayerObj->draw(). In my code, I step through each of my points and
add them to the LayerObj using LayerObj->addFeature($shape). Then, like
you, I call Point->draw(MapObj,LayerObj,Img,...). But what is the
difference between calling Point->draw() for each point as it is added
to the layer, or calling LayerObj->draw() after all the points have been
added to the layer? It seems to me that once all the points (or
whatever other objects) are added to the layer, calling LayerObj->draw()
would do the trick.
Matt
-----Original Message-----
Sent: Wednesday, August 13, 2003 9:27 AM
To: mdoggett at coas.oregonstate.edu
Cc: Mapserver List
Subject: Re: [Mapserver-users] help with ???->draw() mapscript function
If you use MapObj->prepareImage() you should not use MapObj->draw(). You
are responsible to do all the drawing using LayerObj->draw(), which
draws on the image prepared and Point->draw() or Rect->draw() etc. which
take both the prepared image and a layerObj. After you've finished all
your drawing you should call MapObj->drawLabelCache($img) to draw the
labels.
Typically I loop thru each layerObj, turning it on and calling
LayerObj->draw(). I make sure to skip any dynamic point layers.
Then I get the point layer obj and call Point->draw() for each point:
$point->draw($map, $layerObj, $img, undef, $text);
Finally I call $MapObj->drawLabelCache($img);
HTH
Eric
On Wed, 2003-08-13 at 19:17, Matt Doggett wrote:
> Can anyone help me out with the mapscript "draw" function?
> From what I see we've got a PointObj->draw(), LayerObj->draw(),
> MapObj->draw(), RectObj-draw(), etc. etc. So which one should I use?
> I'm using mapscript to dynamically create a layer containing point
> observations and I get different results depending on which object
> function I use.
> Matt
> Matt Doggett
> Spatial Climate Analysis Service
> Oregon State University
> 316 Strand Ag Hall
> Corvallis, OR 97331
> (541)737-9153
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
