[Mapserver-users] SunONE chokes on template file
Martin Weinelt
mweinelt at planiglobe.com
Thu Aug 14 05:12:57 EDT 2003
Jean-Francois.Doyon wrote:
> If you have 4.0, you can use -QUERY_STRING="map=..." (Or is it -QUERYSTRING
> ?) as an option to the executable form the command line. With the proper
> query string, you can get mapserver to go through the template parsing, and
> see if it dies there too.
> Doesn't provide a solution, but might help find the cause ...
> Hope this helps ...
I have now compiled (gcc 2.95.3) and installed 4.0 at the site (SunOS 5.9
Generic_112233-05 sun4u sparc SUNW,Sun-Fire-880):
./configure --prefix=/somedir/mapserver/local
--with-zlib=/somedir/mapserver/packages/zlib
--with-gd=/somedir/mapserver/packages/gd-2.0.15
--enable-runpath --with-threads
--enable-internal-ld-detect --without-gdal
--with-png=/somedir/mapserver/local/bin/libpng12-config
--with-tiff=../tiff-v3.6.0-beta --with-proj=../proj-4.4.7
--with-jpeg=../jpeg-6b --with-freetype=../../local/bin/freetype-config
The need for a script adding LD_LIBRARY_PATH was gone with the
--enable-runpath option.
If I now use "./mapserv QUERY_STRING=..." on the command-line as suggested by
Jean-Francois I get a Segmentation fault. So I guess the SunONE server has
nothing to do with the problems. Maybe still a problem in conflicting libs.
ldd mapserv
libgd.so.2 => /somedir/mapserver/local/lib/libgd.so.2
libfreetype.so.6 => /somedir/mapserver/local/lib/libfreetype.so.6
libpng.so.2 => /somedir/mapserver/local/lib/libpng.so.2
libXpm.so.4 => /opt/sfw/lib/libXpm.so.4
libX11.so.4 => /usr/openwin/lib/libX11.so.4
libtiff.so => /somedir/mapserver/local/lib/libtiff.so
libproj.so.0 => /somedir/mapserver/local/lib/libproj.so.0
libpthread.so.1 => /usr/lib/libpthread.so.1
libm.so.1 => /usr/lib/libm.so.1
libc.so.1 => /usr/lib/libc.so.1
libpng.so.3 => /somedir/mapserver/local/lib/libpng.so.3
libz.so.1 => /usr/lib/libz.so.1
libXext.so.0 => /usr/openwin/lib/libXext.so.0
libsocket.so.1 => /usr/lib/libsocket.so.1
libnsl.so.1 => /usr/lib/libnsl.so.1
libdl.so.1 => /usr/lib/libdl.so.1
libmp.so.2 => /usr/lib/libmp.so.2
libthread.so.1 => /usr/lib/libthread.so.1
librt.so.1 => /usr/lib/librt.so.1
libaio.so.1 => /usr/lib/libaio.so.1
libmd5.so.1 => /usr/lib/libmd5.so.1
/usr/platform/SUNW,Sun-Fire-880/lib/libc_psr.so.1
/usr/platform/SUNW,Sun-Fire-880/lib/libmd5_psr.so.1
Does anyone had similar problems ( and a tip ) or can comment?
Thanks, Martin
