[Mapserver-users] Oracle Spatial and MapServer
Bart van den Eijnden
bartvde at xs4all.nl
Thu Aug 14 15:33:31 EDT 2003
You should specify among others (see OGC WMS 1.1 specs):
-which layers you want to see
-the spatial extent in which you want to see them
etc.
The URL you sent is not complete/valid GetMap request.
Or didn't the complete URL get pasted into your e-mail?
Best regards,
Bart
On Wed, 13 Aug 2003 17:53:32 -0700, Averill Cate, Jr.
<acate at email.arizona.edu> wrote:
> Hi,
> I got MapServer 4 talking to my Oracle server, however when I test the
> mapserver with:
> http://dss-dev/cgi-
> bin/mapserv.exe?map=C:\oracle\ora92\Apache\Apache\htdocs\wg\wg.map&VERSION=1.1.0&REQUEST=GetMap
> I get a blank image back from Map Server. There should be two layers
> according to my map definition which is listed below the dashed line.
> Does anyone know why the layers don't display? Thanks for any help.
> # Generic MapServer MapFile with all potential elements (commented out)
> # Begin with the 'root' map element
> map
> EXTENT 580217 3503392 606269 3515517
> IMAGECOLOR 200 200 200 #IMAGECOLOR [r] [g] [b]
> IMAGETYPE PNG #IMAGETYPE [gif|png|jpeg|wbmp]
> INTERLACE ON #INTERLACE [on|off]
> NAME "WG" #NAME [name]
> # SHAPEPATH "shapefiles/" #SHAPEPATH [filename]
> SIZE 600 600 #SIZE [x][y]
> STATUS ON #STATUS [on|off]
> UNITS meters #UNITS [feet|inches|kilometers|meters|miles|dd]
> PROJECTION
> "init=epsg:26912" #"init=epsg:4326"
> END # PROJECTION
> WEB EMPTY "/wg/empty.html" #EMPTY [url]
> :relative to the web root of the server, in a directory from which html
> documents can be retreived
> TEMPLATE "wg_template.html" #TEMPLATE [filename|url]
> IMAGEPATH "/tmp/" #IMAGEPATH [path]
> IMAGEURL "/tmp/" #IMAGEURL [path]
> LOG "/tmp/map.log" #LOG [filename]
> METADATA END # METADATA END # WEB
> LEGEND
> imagecolor 200 200 200
> status on
> END # Legend
> # The sub-basin layer
> LAYER
> NAME "SubWatersheds" #NAME [string]
> DATA "GEOMETRY from WATERSHEDS"
> TYPE polygon #TYPE [point|line|polygon|circle|annotation|raster|query]
> CONNECTIONTYPE oraclespatial
> CONNECTION "gis/gis at ORCL_DSS-DEV"
> LABELITEM "major_subw" #LABELITEM [attribute]
> STATUS on #STATUS [on|off|default]
> TEMPLATE "results_watersheds.html" #TEMPLATE [file|url]
> METADATA
> END # METADATA
> CLASS
> NAME "watersheds" #NAME [string]
> TITLE "Sub Watersheds"
> OUTLINECOLOR 0 0 0 #OUTLINECOLOR [r][g][b]
> LABEL
> ANTIALIAS true #ANTIALIAS [true|false]
> COLOR 255 255 255 #COLOR [r][g][b]
> SIZE medium #SIZE [integer]|[tiny|small|medium|large|giant]
> TYPE bitmap #TYPE [bitmap|truetype]
> END # LABEL
> END # CLASS
> PROJECTION
> "init=epsg:26912"
> END # PROJECTION
> END # Sub-Basin LAYER
> LAYER # Streams
> name "Streams"
> data "geometry from STREAMS"
> type line
> connectiontype oraclespatial
> connection "gis/gis at ORCL_DSS-DEV"
> status on
> template "results_streams.html"
> CLASS
> name "Streams"
> title "Streams"
> outlinecolor 0 0 255
> END # End class
> PROJECTION
> "init=epsg:26912"
> END # Projection
> END # Streams layer
> END # MAP
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
