[Mapserver-users] Confused about QuerybyPoint with PostGIS
Paul Ramsey
pramsey at refractions.net
Thu Aug 14 20:16:53 EDT 2003
This bug in PHP mapscript *was* identified and killed, but I do not know
if the fix resides in the 3.7 series or only in the 4.0 series.
Daniel knows though... :)
P
Bill Wheaton wrote:
> Hello--
> I have experienced a problem reported by other users trying to use
> QueryByPoint on a PostGIS data source. The error message is:
> Fatal error : Assertion failed, Could not set shape values: 0, 0 in
> /Library/WebServer/Documents/file.phtml on line 702
> I saw follow-up posts regarding a potential fix, but I could not tell if
> the fix is available, or if so, how you get it...Can anyone confirm that
> the problem noted above has been fixed?
> If I do not have the option of upgrading to MS 4.0 (assuming that's
> where any fix would be), is there any possible workaround for the
> problem using, for example, MS 3.6.6?
> Many thanks.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
