[Mapserver-users] Linux RedHat 9.0 php/mapscript installation
Alexander Shostko
shostko at ureach.com
Fri Aug 15 02:02:11 EDT 2003
Dear List !
The brief description of the problem:
I am porting php/mapscript application
(php-4.3.2/apache-1.3.27)
from Windows to Linux
Linux is Red-Hat 9.0, php is 4.3.2, apache is 1.3.28
installed in /etc/httpd and /var/www/ as typical.
mapserver-3.6.6
The installation flags and options are below. All compiles
fine. But does
not run at all. It did not even come to
mapscript. The php itself does not work with apache as cgi .
When I try to run simple
<?php
// nothing works
dl("php_mapscript.so");
phpinfo();
gives
Warning: Unexpected character in input: '(ASCII=15) state=1 in
/var/www/cgi-bin/php on line 3395
Warning: Unexpected character in input: '^B' (ASCII=2) state=1
in /var/www/cgi-bin/php on line 3395
Warning: Unexpected character in input: ' in
Parse error: parse error in /var/www/cgi-bin/php on line 3395
which means that php simply not working whether I use dl(..) or
not.
I tried also httpd-2.0.47 etc. same results. ALso I tried from
tarball
(Linux 9.0 installation) of apache/php . Same results.
The possible options are:
--Install older / stabler RedHat (8.0 for ex, 9.0 is very new)
--Install apache 1.3.27 or older
--try php-4.3.0 or 4.2.x until I have at least apache-php as cgi
working,
then put mapscript there.
Any ideas on which Linux/apache/php/options or simly what I am
missing ?
Thanks a lot
Alex
Simulation Tech.
engineer
The apache is compiled with:
rm config.cache
./configure \
--prefix=/etc/httpd/ \
--enable-module=all \
--enable-shared=max \
--with-layout=RedHat \
--disable-rule=WANTHSREGEX=no
php is compiled with:
rm config.cache
./configure \
--with-regex=system \
--with-config-file-path=/etc/httpd/ \
--enable-safe-mode \
--enable-force-cgi-redirect \
--enable-discard-path \
--enable-versioning \
--enable-magic-quotes \
--enable-track-vars \
--with-gd \
--with-zlib \
--with-jpeg \
--with-ming \
--with-xml \
--with-ftp \
--with-regex=system
when making make test it tells that:
CWD : /usr/local/php-4.3.2
PHP : /usr/local/php-4.3.2/sapi/cli/php
PHP_SAPI : cli
PHP_VERSION : 4.3.2
ZEND_VERSION: 1.3.0
PHP_OS : Linux
INI actual : /etc/httpd/php.ini
More .INIs :
Extra dirs :
TIME START 2003-08-15 01:47:20
The mapscript is compiled with:
rm -r config.cache
./configure \
--without-tiff \
--without-eepl \
--with-jpeg \
--with-threads \
--with-proj \
--with-gdal \
--with-php=../php-4.3.2 \
--with-gd=/usr/local \
--with-freetype=/usr/bin \
--with-pdf \
--with-ogr \
--with-ming \
--with-wmsclient \
--with-wfs \
--with-wfs-client
