[Mapserver-users] Re: Linux RedHat 9.0 php/mapscript installation
pkishor_98
pkishor at geoanalytics.com
Fri Aug 15 09:55:27 EDT 2003
as suggested, first check if php itself is running correctly. funny, just yesterday I
compiled the whole shebang on RH9. Took about 5 hours from start to finish but worked
without a scratch. I used Erich Schroeder's instructions on the as a guide... fantanstic
instructions. I didn't install ming, but everything else worked just as advertised. The
instructions are at http://mapserver.gis.umn.edu/cgi-bin/
wiki.pl?RedHat9AndMapserver40b. The only thing, this is all about MapServer 4. I didn't
try the older version.
So. yes RH9 with PHP4.3.2 and Apache 2.0.47, Perl 5.8.0 work just fine with MapServer 4.
Do make sure that php itself works, and then try php_mapscript.so.
> -----Original Message-----
> From: Alexander Shostko [mailto:shostko at u...]
> Sent: Friday, August 15, 2003 3:02 AM
> To: mapserver-users at l...
> Subject: [Mapserver-users] Linux RedHat 9.0 php/mapscript installation
> Dear List !
> The brief description of the problem:
> I am porting php/mapscript application
> (php-4.3.2/apache-1.3.27)
> from Windows to Linux
> Linux is Red-Hat 9.0, php is 4.3.2, apache is 1.3.28
> installed in /etc/httpd and /var/www/ as typical.
> mapserver-3.6.6
> The installation flags and options are below. All compiles
> fine. But does
> not run at all. It did not even come to
> mapscript. The php itself does not work with apache as cgi .
> When I try to run simple
> <?php
> // nothing works
> dl("php_mapscript.so");
> phpinfo();
> gives
> Warning: Unexpected character in input: '(ASCII=15) state=1 in
> /var/www/cgi-bin/php on line 3395
> Warning: Unexpected character in input: '^B' (ASCII=2) state=1
> in /var/www/cgi-bin/php on line 3395
> Warning: Unexpected character in input: ' in
> Parse error: parse error in /var/www/cgi-bin/php on line 3395
> which means that php simply not working whether I use dl(..) or
> not.
> I tried also httpd-2.0.47 etc. same results. ALso I tried from
> tarball
> (Linux 9.0 installation) of apache/php . Same results.
> The possible options are:
> --Install older / stabler RedHat (8.0 for ex, 9.0 is very new)
> --Install apache 1.3.27 or older
> --try php-4.3.0 or 4.2.x until I have at least apache-php as cgi
> working,
> then put mapscript there.
> Any ideas on which Linux/apache/php/options or simly what I am
> missing ?
> Thanks a lot
> Alex
> Simulation Tech.
> engineer
> The apache is compiled with:
> rm config.cache
> ./configure \
> --prefix=/etc/httpd/ \
> --enable-module=all \
> --enable-shared=max \
> --with-layout=RedHat \
> --disable-rule=WANTHSREGEX=no
> php is compiled with:
> rm config.cache
> ./configure \
> --with-regex=system \
> --with-config-file-path=/etc/httpd/ \
> --enable-safe-mode \
> --enable-force-cgi-redirect \
> --enable-discard-path \
> --enable-versioning \
> --enable-magic-quotes \
> --enable-track-vars \
> --with-gd \
> --with-zlib \
> --with-jpeg \
> --with-ming \
> --with-xml \
> --with-ftp \
> --with-regex=system
> when making make test it tells that:
> CWD : /usr/local/php-4.3.2
> PHP : /usr/local/php-4.3.2/sapi/cli/php
> PHP_SAPI : cli
> PHP_VERSION : 4.3.2
> ZEND_VERSION: 1.3.0
> PHP_OS : Linux
> INI actual : /etc/httpd/php.ini
> More .INIs :
> Extra dirs :
> TIME START 2003-08-15 01:47:20
> The mapscript is compiled with:
> rm -r config.cache
> ./configure \
> --without-tiff \
> --without-eepl \
> --with-jpeg \
> --with-threads \
> --with-proj \
> --with-gdal \
> --with-php=../php-4.3.2 \
> --with-gd=/usr/local \
> --with-freetype=/usr/bin \
> --with-pdf \
> --with-ogr \
> --with-ming \
> --with-wmsclient \
> --with-wfs \
> --with-wfs-client
> Mapserver-users mailing list
> Mapserver-users at l...
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> This e-mail and any files transmitted with it are provided for convenience only
> and is to be considered confidential and are intended solely for the use
> of the individual to whom it is addressed. If you have received this e-mail
> in error please notify the sender immediately.
> CBCL Limited assumes no responsibility for data supplied electronically by e-mail
> and any unauthorized use or changes to such data is strictly prohibited. CBCL
> Limited maintains all rights and copyrights to e-mailed electronic files.
> This message has been scanned for the presence of computer viruses, however
> no warranty is given that this messge upon it's receipt is virus free and no liability
> is accepted by the sender in this respect.
