[Mapserver-users] Processing with tileindex
Damian Schroder
map_surfer at yahoo.com
Fri Aug 15 16:16:29 EDT 2003
--0-366343719-1060978589=:56279
Content-Type: text/plain; charset=us-ascii
Greetings,
We are trying to create a tileindex using 6 band Landsat imagery. We have been successful using OFFSITE with a tileindex but the PROCESSING option seems to give the tileindex trouble. The PROCESSING option worked fine for specifying the bands in a single raster layer object. Currently our work around has been to build the TILEINDEX with 3 band images. Does anybody know if the PROCESSING option is compatible with the TILEINDEX option?
Thanks,
Damian
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
Content-Type: text/html; charset=us-ascii
<DIV>Greetings,</DIV>
<DIV> </DIV>
<DIV>We are trying to create a tileindex using 6 band Landsat imagery. We have been successful using OFFSITE with a tileindex but the PROCESSING option seems to give the tileindex trouble. The PROCESSING option worked fine for specifying the bands in a single raster layer object. Currently our work around has been to build the TILEINDEX with 3 band images. Does anybody know if the PROCESSING option is compatible with the TILEINDEX option?</DIV>
<DIV> </DIV>
<DIV>Thanks, </DIV>
<DIV>Damian </DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://us.rd.yahoo.com/evt=10469/*http://sitebuilder.yahoo.com">Yahoo! SiteBuilder</a> - Free, easy-to-use web site design software
--0-366343719-1060978589=:56279--
