[Mapserver-users] PostGIS Query Results
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Aug 18 18:03:43 EDT 2003
Damian,
Just as I thought. Check your error log as it will surely contain
relevant info about what's causing this "internal error". Your
application is just fine, I think you're missing a library required by
MapServer (possibly libpq.so). This could also be due to having
duplicate copies of some libraries (or having compiled against different
versions of libraries?).
I don't use PHP/MapScript so others could probably give you more
specific pointers as to what could cause this problem.
-Perry
On Mon, 2003-08-18 at 16:17, Damian Schroder wrote:
> Below is my error message from preforming a query with
> PostGIS data layers. Mapserver/Rosa is working great
> in that all my vector based data is being displayed. I
> have other PHP application accessing Postgresql easy
> enough. It is something with Rosa/PHP/Mapscript, but
> not sure where.
> TIA
> Internal Server Error
> The server encountered an internal error or
> misconfiguration and was unable to complete your
> request.
> Please contact the server administrator,
> webmaster at localhost and inform them of the time the
> error occurred, and anything you might have done that
> may have caused the error.
> More information about this error may be available in
> the server error log.
> Apache/1.3.27 Server at localhost Port 80
> --- "Pericles S. Nacionales" <nacional at cbs.umn.edu>
> wrote:
> > And what might the message be? Without knowing
> > where to start, I'll
> > shoot blindly and claim that your error is due to
> > missing PostGIS client
> > library. :) If not, then I would say you forgot to
> > update all your
> > libraries and application files. I tell you this
> > because they are the
> > two most common problems that people seem to run
> > into these days.
> > But really, what does the error message say? Don't
> > forget to check
> > Apache's error log as well.
> > Good luck!
> > Perry N.
> > On Mon, 2003-08-18 at 14:49, Damian Schroder wrote:
> > > I originally built a site (PHP/MapScript)
> > accessing
> > > shapefiles. Using the ROSA applet the query worked
> > > fine. Now that I switched over to PostGIS it
> > doesn't
> > > work and returns a server error(apache style).
> > Does
> > > anyone have any ideas why this would happen? (RH9
> > > Mapserver 4.0b)
> > > TIA
> > > __________________________________
> > > Do you Yahoo!?
> > > Yahoo! SiteBuilder - Free, easy-to-use web site
> > design software
> > > http://sitebuilder.yahoo.com
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Pericles S. Nacionales <nacional at cbs.umn.edu>
> > University of Minnesota
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site design software
