[Mapserver-users] CGI Error - Resolution - Permissions with IIS
Dustin Harrison
dustinlharrison at yahoo.com
Tue Aug 19 00:55:11 EDT 2003
--0-547692179-1061268911=:49388
Content-Type: text/plain; charset=us-ascii
Unfornunately a number of us have committed to using IIS as a web server and have thus inherited the headaches of this system. I have recently been up against a configuration issue where I recieved a CGI Error from IIS and I could not resolve it, even by going back to different Mapserver builds with less and less dependencies (the problem started when I attempted to install Mapserver with a mapscript build).
The final resolution to the problem involved giving pdflib.dll permissions to be read and run by IUSR_machinename I can now run mapserver. In addtion I was unable to use dl() to open php_mapscript40.dll or php_proj.dll however this problem was also solved by the new permissions. This is the only file I had to explicity set (except of course mapserver.exe, php_mapscript40.dll, php_proj.dll).
This doesn't seem to make sense. I'd appreciate any feedback/insight on this particular case, but more importantly I wanted to post this to hopefully help anyone that also had this problem.
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
Content-Type: text/html; charset=us-ascii
<DIV>Unfornunately a number of us have committed to using IIS as a web server and have thus inherited the headaches of this system. I have recently been up against a configuration issue where I recieved a CGI Error from IIS and I could not resolve it, even by going back to different Mapserver builds with less and less dependencies (the problem started when I attempted to install Mapserver with a mapscript build).</DIV>
<DIV> </DIV>
<DIV>The final resolution to the problem involved giving pdflib.dll permissions to be read and run by IUSR_machinename I can now run mapserver. In addtion I was unable to use dl() to open php_mapscript40.dll or php_proj.dll however this problem was also solved by the new permissions. This is the only file I had to explicity set (except of course mapserver.exe, php_mapscript40.dll, php_proj.dll).</DIV>
<DIV> </DIV>
<DIV>This doesn't seem to make sense. I'd appreciate any feedback/insight on this particular case, but more importantly I wanted to post this to hopefully help anyone that also had this problem.</DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://us.rd.yahoo.com/evt=10469/*http://sitebuilder.yahoo.com">Yahoo! SiteBuilder</a> - Free, easy-to-use web site design software
--0-547692179-1061268911=:49388--
