[Mapserver-users] Help !!! Mapscript installation nightmare !!
Randy James
rjames57 at yahoo.com
Wed Aug 20 17:23:02 EDT 2003
Hi
Maybe try with GD-2.0.15
Cheers
--- "D. Scott Davidson" <davidson at usgs.gov> wrote:
> I appreciate the suggestions. thanks.
> I tried to configure mapserver with:
> rm config.cache
> configure --without-tiff --with-proj=/usr/local/lib
> --with-gdal=/usr/opt/bin/gdal-config --with-wmsclient
> --with-gd=/usr/lib
> --with-php=/usr/local/include/php/
> --enable-internal-ld-detect
> make clean
> make
> copied php_mapscript.so to its place.
> I still got the error:
> Warning: dl(): Unable to load dynamic library
> '/usr/opt/lib/php/extensions/php_mapscript.so' - ld.so.1:
> /usr/local/apache/bin/httpd: fatal: relocation error:
> file
> /usr/opt/lib/php/extensions/php_mapscript.so:
> symbol gdImageSetClip: referenced symbol not found in
> /www/htdocs/phpinfo_mapscript.php on line 21
> My gdal version is gdal-1.1.8.
> I configured PHP like this:
> ./configure --with-system-regex
> --with-apache=../apache_1.3.26/
> --with-pgsql.
> There has to be a simple answer here.
> Thanks in advance.
> "Charlton Purvis"
> <cpurvis at asg.sc.edu>
> To: "D. Scott Davidson" <davidson at usgs.gov>,
> Sent by:
> <mapserver-users at lists.gis.umn.edu>
> mapserver-users-admin at lists.
> cc:
> gis.umn.edu
> Subject: RE: [Mapserver-users] Help !!! Mapscript
> 08/20/2003 01:48 PM
> Try adding
> to your mapserver ./configure.
> If that doesn't help, what is your php configuration?
> Charlton
> > -----Original Message-----
> > From: D. Scott Davidson [mailto:davidson at usgs.gov]
> > Sent: Wednesday, August 20, 2003 2:34 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Cc: D. Scott Davidson
> > Subject: [Mapserver-users] Help !!! Mapscript
> > Hello,
> > I have spent an enormous amount of time trying to get
> php-mapscript to
> > work.
> > This has truly been a nightmare.
> > I have built php-4.3.2 as part of apache_1.3.26 on
> Solaris 2.8 .
> > This builds fine, and php works.
> > I then built and installed mapserver-4.0.
> > I configured mapserver with this:
> --with-gdal
> > --with-wmsclient --with-gd=/usr/lib
> > It made fine.
> > I then copied the mapserver.so to the php directory,
> edited the
> php.ini
> > file.
> > When running the phpinfo_mapscript.php test file I get
> these errors:
> > ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation
> error: file
> > /usr/opt/lib/php/extensions/php_mapscript.so: symbol
> gdImageSetClip:
> > in /www/htdocs/phpinfo_mapscript.php on line 21
> > This has been maddening - does anyone know how to fix
> this ?
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
