[Mapserver-users] Help !!! Mapscript installation nightmare !!
Vincent Schut
schut at sarvision.com
Thu Aug 21 03:23:59 EDT 2003
D.,
possibly this is because php uses its own version of gd, which might be
different from the one you compile mapscript with. This could lead to
relocation errors. Try recompiling php with '--with-gd=/usr/lib' to make sure
php uses the same gd as mapscript. Btw, you cannot use mapscript with php
compiled as a apache module. You will need php as a cgi application, so omit
the --with-apache option when compiling php. You can find (lots of) more info
about this on the website/wiki at the install sections, and in the mailing
list archive.
You might also consider using mapserver 4.0, which is the latest stable
release and has a lot of added features and bug fixes. If you do so, you will
need a newer gd, at least 2.0.12 but you'd better use the newest one, 2.0.15
afaik.
Cheers,
Vincent.
On Wednesday 20 August 2003 20:33, D. Scott Davidson wrote:
> Hello,
> I have spent an enormous amount of time trying to get php-mapscript to
> work.
> This has truly been a nightmare.
> I have built php-4.3.2 as part of apache_1.3.26 on Solaris 2.8 .
> This builds fine, and php works.
> I then built and installed mapserver-4.0.
> I configured mapserver with this:
> configure --without-tiff --with-proj=/usr/local/lib --with-gdal
> --with-wmsclient --with-gd=/usr/lib --with-php=/usr/local/include/php/
> It made fine.
> I then copied the mapserver.so to the php directory, edited the php.ini
> file.
> When running the phpinfo_mapscript.php test file I get these errors:
> Warning: dl(): Unable to load dynamic library
> '/usr/opt/lib/php/extensions/php_mapscript.so' -
> ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
> /usr/opt/lib/php/extensions/php_mapscript.so: symbol gdImageSetClip:
> referenced symbol not found
> in /www/htdocs/phpinfo_mapscript.php on line 21
> This has been maddening - does anyone know how to fix this ?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
