[Mapserver-users] Problems: msQueryByPoint, Premature end of
script headers
Gerry Creager
gerry.creager at tamu.edu
Thu Aug 21 19:08:11 EDT 2003
I'll give it a try.
Thanks.
Gerry
Bruce Bushby wrote:
> well that is a large mapfile to debug, perhaps remove everything and just
> call one layer.
> I noticed you open a projection object with hashed contents, perhaps hash
> both
> the PROJECTION and END tags.
> The error you're getting is normally associated with HTTPD not receiving a
> 'content-type' ie mapserver didn't sent the 'header'. Also try use shp2img
> on
> your mapfile and see what happens.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Gerry
> Creager
> Sent: Friday, August 22, 2003 12:10 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Problems: msQueryByPoint, Premature end of
> script headers
> MS 3.7beta (I'll upgrade asap after the demo next Wed! Really!)
> RedHat 9
> [root at mesonet ~]# /var/www/cgi-bin/mapserv -v
> MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> Mapfile's attached in case that helps. I'm at a loss...
> THanks, Gerry
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020
> FAX: 979.847.8578 Pager: 979.228.0173
> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Network Engineering -- AATLT, Texas A&M University
