[Mapserver-users] 24Bit tiff images displayed in greyscale (no bug 270) and no png
files are displayed
Michael Härtel
mhaerte1 at gwdg.de
Fri Aug 22 04:47:00 EDT 2003
Hello World!
GIVEN:
precompiled MAPSERVER on WINDOWS XP
(from mapserver-4.0-win32-php4.3.2.zip):
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
MAPSCRIPT:
($Revision: 1.177 $ $Date: 2003/07/30 19:01:31 $)
GD2 LIBRARY (from phpinfo()):
GD Support enabled
GD Version bundled (2.0.12 compatible)
MAPFILE:
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
TRANSPARENT OFF
EXTENSION "png"
END
- snip!-
LAYER
PROJECTION
proj=longlat
ellps=WGS84
datum=WGS84
no_defs
END
NAME "test"
STATUS OFF
data "test.png" ### a 24Bit PNG or tif image with world file
TYPE RASTER
GROUP "raster background"
CLASS
NAME "test" // only to generate legend entry
END
END
PROBLEMS:
1.) 24Bit tiff images are displayed in grayscale although output is RGB
PNG and GD2 is obviously used. I know about "bug" No 270
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=270) but even if i
leave out the class defining lines within the mapfile no image is
produced (empty map).
2.) PNG files are not displayed (24 and 8 bit), they are simply empty, a
white image returns.
They seem to be drawn (the legend has an entry for that raster layer),
no error messages available.
My reference map is a png image and the entire map output works fine
with png images as long as no png images are included in layer definitions.
QUESTION:
How can i convince mapserver to display 24Bit images (tiff or png)?
