[Mapserver-users] HELP!! My Demo is shooting blanks!!
Lowther, David W dlowther at ou.edu
Fri Aug 22 11:17:54 EDT 2003
Michael,
Your mapfile reads:
EXTENT 176871 41.619778 -82.122902 49.38562
UNITS DD
The 176871 number is not an acceptable DD value...
Also, always reply to all so the list gets your messages also.
David Lowther
Software Engineer
GEO Information Systems
University of Oklahoma
dlowther at ou.edu
(405) 325-3131
http://www.geo.ou.edu
> -----Original Message-----
> From: Michael Smith [mailto:msmith at sanangelompo.org]
> Sent: Friday, August 22, 2003 10:06 AM
> To: Lowther, David W
> Subject: RE: [Mapserver-users] HELP!! My Demo is shooting blanks!!
> Oops! I pasted the wrong code.  The second extent (#EXTENT
> -180.0 -90.0 180.0 90.0) what I am using with my demo and DD
> units and getting the blank screen.  Any other suggestions?
> > MAP
> >   # Start of map file
> >   NAME "DEMO"
> >   STATUS ON
> >   #EXTENT -180.0 -90.0 180.0 90.0
> >   SIZE 600 600
> >   SHAPEPATH "data"
> >   IMAGECOLOR 255 255 255
> >   UNITS DD
> From: Lowther, David W [mailto:dlowther at ou.edu]
> Sent: Friday, August 22, 2003 9:46 AM
> To: 'Michael Smith'; mapserver-users at lists.gis.umn.edu
> Looks like your units don't jive with your extent.
> David Lowther
> Software Engineer
> dlowther at ou.edu
> (405) 325-3131
> > Sent: Friday, August 22, 2003 9:34 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] HELP!! My Demo is shooting blanks!!
> > I have the Itasca demo up and running on windows 2000 IIS 5. When I
> > insert my shapefile (tgrds and usa) into the demo and change the
> > extents, I get a blank demo screen.  Everything else looks
> the same I
> > even have my counties boundary reference file appear on the right.
> > Any ideas will be very much apppreciated!!!
> > Here is my demo_init.html file:
> > MAP
> >   # Start of map file
> >   NAME "DEMO"
> >   STATUS ON
> >   SIZE 600 600
> >   SHAPEPATH "data"
> >   UNITS DD
> >   # you may need to change this to match your MapServer build
> >   #IMAGETYPE PNG
> >   # Projection definition, consult the PROJ.4 documentation for
> > parameter discussion
> >   #PROJECTION
> >   #  "proj=utm"
> >   #  "ellps=GRS80"
> >   #  "zone=15"
> >   #  "north"
> >   #  "no_defs"
> >   #  OR:
> >   #  "init=epsg:26915"
> >   #END
> >   # Start of web interface definition (including WMS enabling
> > metadata)
> >   WEB
> >     MINSCALE 1000
> >     MAXSCALE 5550000
> >     IMAGEPATH "set in cosademo_init.html"
> >     IMAGEURL "set in cosademo_init.html"
> >     HEADER "demo_header.html"
> >     FOOTER "demo_footer.html"
> >     TEMPLATE "cosademo.html"
> >     METADATA
> >       "WMS_TITLE"    "UMN MapServer Itasca Demo"
> >       "WMS_ABSTRACT"    "This is the UMN MapServer
> > demonstration application
> > for Itasca County located in north central Minnesota."
> >       "WMS_ACCESSCONSTRAINTS"    "none"
> >       "WMS_ONLINERESOURCE"
> > "http://192.168.110.21/itasca/cosademo_init.html"
> >       "WMS_SRS"    "EPSG:26915"
> >     END
> >   END
> >   # Start of reference map
> >   REFERENCE
> >     STATUS ON
> >     IMAGE "graphics/cosarefer.gif"
> >     SIZE 120 120
> >     COLOR -1 -1 -1
> >     OUTLINECOLOR 255 0 0
> >   END
> >   QUERYMAP
> >     STATUS ON
> >     SIZE 200 200
> >     COLOR 255 0 0
> >     STYLE HILITE
> >   END
> >   # Start of legend
> >   LEGEND
> >     STATUS ON
> >     KEYSIZE 18 12
> >     LABEL
> >       TYPE BITMAP
> >       SIZE MEDIUM
> >       COLOR 0 0 89
> >     END
> >   END
> >   # Start of scalebar
> >   SCALEBAR
> >     STATUS TRUE
> >     COLOR 255 255 255
> >     UNITS MILES
> >     INTERVALS 1
> >     SIZE 80 2
> >     STYLE 1
> >     LABEL
> >       SIZE tiny
> >       COLOR 255 255 255
> >     END
> >   END
> >   # Start of symbol definitions (we're only using a few)
> >   SYMBOL
> >     NAME "circle"
> >     TYPE ELLIPSE
> >     FILLED TRUE
> >     POINTS
> >        1 1
> >     END
> >   END
> >   # Start of layer definitions
> >   LAYER
> >     NAME "ctybdpy2"
> >     STATUS OFF
> >     DATA "ctybdpy2"
> >     TYPE POLYGON
> >     CLASSITEM "cty_name"
> >     METADATA
> >       "WMS_TITLE"    "County Boundary"
> >       "WMS_ABSTRACT"    "Itasca County boundary shapefile. See
> > http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
> > information."
> >     END
> >     CLASS
> >       EXPRESSION "Itasca"
> >       COLOR 225 225 185
> >       OUTLINECOLOR 128 128 128
> >     END
> >     CLASS
> >       # every other county in the state
> >       EXPRESSION /./
> >       COLOR 255 255 255
> >     END
> >   END
> >   LAYER
> >     NAME "mcd90py2"
> >     GROUP "cities"
> >     STATUS OFF
> >     DATA "mcd90py2"
> >     TYPE POLYGON
> >     CLASSITEM "city_name"
> >     HEADER "mcd90py2_header.html"
> >     FOOTER "mcd90py2_footer.html"
> >     # allow GML export
> >     METADATA
> >       "WMS_TITLE"    "Minor Civil Divisions"
> >       "WMS_ABSTRACT"    "Minor civil divisions for Itasca County.
> > (boundaries only)"
> >     END
> >     CLASS
> >       NAME "Cities & Towns"
> >       EXPRESSION /./
> >       COLOR 255 225 90
> >       TEMPLATE "mcd90py2.html"
> >     END
> >   END
> >   LAYER
> >     NAME "twprgpy3"
> >     STATUS OFF
> >     DATA "twprgpy3"
> >     TYPE POLYGON
> >     METADATA
> >       "WMS_TITLE"    "Township Boundaries"
> >       "WMS_ABSTRACT"    "Pulic Land Survey (PLS) township
> > boundaries for
> > Itasca County. See
> > http://deli.dnr.state.mn.us/metadata/full/twprgne2.html
> > for more information."
> >     END
> >     CLASS
> >       NAME "Townships"
> >       SYMBOL "circle"
> >       OUTLINECOLOR 181 181 145
> >       SIZE 2
> >     END
> >   END
> >   LAYER
> >     NAME "lakespy2"
> >     STATUS OFF
> >     DATA "lakespy2"
> >     TYPE POLYGON
> >     TOLERANCE 3
> >     HEADER "lakespy2_header.html"
> >     FOOTER "lakespy2_footer.html"
> >     # allow GML export
> >     METADATA
> >       "WMS_TITLE"    "Lakes and Rivers"
> >       "WMS_ABSTRACT"    "DLG lake and river polygons for
> > Itasca County. See
> > http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
> > information."
> >     END
> >     CLASS
> >       NAME "Lakes & Rivers"
> >       COLOR 49 117 185
> >       TEMPLATE "lakespy2.html"
> >     END
> >   END
> >   # lakes
> >   LAYER
> >     NAME "dlgstln2"
> >     STATUS OFF
> >     DATA "dlgstln2"
> >     TYPE LINE
> >     TOLERANCE 5
> >     HEADER "dlgstln2_header.html"
> >     FOOTER "dlgstln2_footer.html"
> >     # allow GML export
> >     METADATA
> >       "WMS_TITLE"    "Streams"
> >       "WMS_ABSTRACT"    "DLG streams for Itasca County. See
> > http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
> > information."
> >     END
> >     CLASS
> >       NAME "Streams"
> >       COLOR 49 117 185
> >       TEMPLATE "dlgstln2.html"
> >     END
> >   END
> >   # streams
> >   LAYER
> >     NAME "ctyrdln3"
> >     GROUP "roads"
> >     STATUS OFF
> >     DATA "ctyrdln3"
> >     TYPE LINE
> >     MAXSCALE 300000
> >     METADATA
> >       "WMS_TITLE"    "County Roads"
> >       "WMS_ABSTRACT"    "County roads. (lines only)  Derived
> > from MNDOT
> > roads layer, see
> > http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more
> > information."
> >     END
> >     CLASS
> >       COLOR 0 0 0
> >     END
> >   END
> >   # county roads
> >   LAYER
> >     NAME "ctyrdln3_anno"
> >     GROUP "roads"
> >     STATUS OFF
> >     DATA "ctyrdln3"
> >     TYPE ANNOTATION
> >     MAXSCALE 300000
> >     LABELITEM "road_name"
> >     METADATA
> >       "WMS_ABSTRACT"    "County roads. (shields only)
> > Derived from MNDOT
> > roads layer, see
> > information."
> >     END
> >     CLASS
> >       SYMBOL "symbols/ctyhwy.gif"
> >       COLOR 255 255 255
> >       LABEL
> >         SIZE TINY
> >         POSITION CC
> >         MINDISTANCE 150
> >         MINFEATURESIZE 40
> >         COLOR 0 0 0
> >       END
> >     END
> >   END
> >   # county road annotation
> >   LAYER
> >     NAME "majrdln3"
> >     GROUP "roads"
> >     STATUS OFF
> >     DATA "majrdln3"
> >     TYPE LINE
> >     MAXSCALE 600000
> >     METADATA
> >       "WMS_TITLE"    "Highways"
> >       "WMS_ABSTRACT"    "Highways- state, US and interstate.
> > (lines only)
> > Derived from MNDOT roads layer, see
> > information."
> >     END
> >     CLASS
> >       NAME "Roads"
> >       COLOR 0 0 0
> >     END
> >   END
> >   # highways
> >   LAYER
> >     NAME "majrdln3_anno"
> >     GROUP "roads"
> >     STATUS OFF
> >     DATA "majrdln3"
> >     TYPE ANNOTATION
> >     CLASSITEM "road_class"
> >     MAXSCALE 600000
> >     LABELITEM "road_num"
> >     METADATA
> > (shields only)
> > information."
> >     END
> >     CLASS
> >       EXPRESSION "3"
> >       # dummy color
> >       SYMBOL "symbols/sthwy.gif"
> >       COLOR 0 0 0
> >       LABEL
> >         SIZE TINY
> >         POSITION CC
> >         MINDISTANCE 150
> >         MINFEATURESIZE 50
> >         COLOR 0 0 0
> >       END
> >     END
> >     CLASS
> >       EXPRESSION "2"
> >       # dummy color
> >       SYMBOL "symbols/ushwy.gif"
> >       COLOR 0 0 0
> >       LABEL
> >         SIZE TINY
> >         POSITION CC
> >         MINDISTANCE 150
> >         MINFEATURESIZE 50
> >         COLOR 0 0 0
> >       END
> >     END
> >     CLASS
> >       EXPRESSION "1"
> >       # dummy color
> >       SYMBOL "symbols/interstate.gif"
> >       COLOR 0 0 0
> >       LABEL
> >         SIZE TINY
> >         POSITION CC
> >         MINDISTANCE 150
> >         MINFEATURESIZE 50
> >         COLOR 255 255 255
> >       END
> >     END
> >   END
> >   # highway annotation
> >   LAYER
> >     NAME "airports"
> >     STATUS OFF
> >     DATA "airports"
> >     TYPE POINT
> >     TOLERANCE 5
> >     HEADER "airports_header.html"
> >     FOOTER "airports_footer.html"
> >     METADATA
> >       "WMS_TITLE"    "Airports"
> >       "WMS_ABSTRACT"    "Airport runways for Itasca County."
> >     END
> >     CLASS
> >       NAME "Airports"
> >       SYMBOL "circle"
> >       COLOR 128 255 164
> >       SIZE 7
> >       TEMPLATE "airports.html"
> >     END
> >   END
> >   LAYER
> >     NAME "cities"
> >     STATUS OFF
> >     DATA "mcd90py2"
> >     TYPE ANNOTATION
> >     LABELITEM "city_name"
> >     LABELMAXSCALE 500000
> >     METADATA
> > (annotation only)"
> >     END
> >     CLASS
> >       EXPRESSION /./
> >       COLOR -1 -1 -1
> >       LABEL
> >         TYPE BITMAP
> >         SIZE MEDIUM
> >         POSITION CC
> >         BUFFER 2
> >         COLOR 0 0 0
> >         SHADOWCOLOR 218 218 218
> >         SHADOWSIZE 2 2
> >         PARTIALS FALSE
> >       END
> >     END
> >   END
> >   LAYER
> >     NAME "tgroads"
> >     STATUS ON
> >     DATA "tgrds"
> >     TYPE LINE
> >     CLASSITEM "Street"
> >     UNITS DD
> >   END
> >   LAYER
> >     NAME "usa"
> >     STATUS DEFAULT
> >     DATA "usa"
> >     TYPE POLYGON
> >     UNITS DD
> >   END
> > END
> > Michael Smith, Planner II
> > City of San Angelo
> > Planning & Development
> > 325.657.4210 Fax: 325.481.2648
> > Email: msmith at sanangelompo.org
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
