[Mapserver-users] "mapserv(): Web application error. No template provided."
Jason Ruiter
Jason.Ruiter at altarum.org
Tue Aug 26 10:36:56 EDT 2003
Greetings,
I'm new to mapserver and am trying to get mapserver 4.0 working. I'm
trying to run through the tutorial. I've modified all of the paths, and
some of the pages (for instance, s1ex1.html) work. The rest of the
time, tho, I get:
I've tried this is mapserver36 and mapserver4. I've attached my
mapserver configuration, the html file in question and the map file in
question.
Any help appreciated...
Thanks
Jason
My mapserver4 configuration:
/usr/lib/cgi-bin$ ./mapserv -v
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
The HTML file:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
<html>
<head>
<title>MapServer 3.5 Tutorial</title>
<link type="text/css" rel="stylesheet"
href="/projects/tutorial35/ms35.css" />
</head>
<body bgcolor="#ffffff">
<h3>Section 1<br>
Example 2 ? A Single Layer with Multiple Classes</h3>
<p><strong>Description:</strong><br>
This example shows you how to create a static web map from a single
data layer.
The layer is shown with three classes, one for each state-- Michigan,
Minnesota,
and Wisconsin.</p>
<p>Sometimes (most of the time, actually) we like to break our data
layer into
logical "classes" based on an attribute (or set of
attributes). Say
we want to show each state in Big Ten college athletics colors, if
for no other
reason. (Apologies to Michigan State and to those who prefer maroon. Have
a look at the map file listing to see how it's done.</p>
<p>[<a href="s1ex2_map.html">Map File Listing</a>]<br>
<img border="1"
src="/cgi-bin/mapserv?map=/var/www/projects/tutorial35/s1/s1ex2.map&mode=map">
</p>
<p><a href="index.html">Back to Section 1</a> | <a
href="/projects/tutorial35/s1/s1ex3.html">Proceed
to Example 3 </a> </p>
</body>
</html>
NAME S1EX2
EXTENT -97.238976 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "/var/www/projects/tutorial35/data"
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "STATE"
CLASS # Michigan class
NAME "Michigan"
EXPRESSION "Michigan"
COLOR 0 0 128
OUTLINECOLOR 0 0 0
END # end of Michigan class object
CLASS # Minnesota class
NAME "Minnesota"
EXPRESSION "Minnesota"
COLOR 255 255 0
OUTLINECOLOR 0 0 0
END # end of Minnesota class object
CLASS # Wisconsin class
NAME "Wisconsin"
EXPRESSION "Wisconsin"
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END # end of Wisconsin class object
END # end of layer object
END # end of map file
-------The map file-----------
Jason Ruiter
Research Computer Engineer, Emerging Technologies Group
Altarum Institute
Ann Arbor, Michigan, USA
(v)734.302.4724 (f)734.302.4991 (m)734.476.8299
Jason.Ruiter at Altarum.org
Jason Ruiter
Altarum Institute
