[Mapserver-users] GeoTIFF Output problem
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 26 11:17:21 EDT 2003
Aaron D. Hunt wrote:
> I am using the following mapfile code (from to doc) to make a geotiff
> OUTPUTFORMAT
> NAME GTiff
> DRIVER "GDAL/GTiff"
> MIMETYPE "image/tiff"
> IMAGEMODE RGB
> EXTENSION "tif"
> END
> The image that comes out is a tiff but it does not seem to be
> georeferenced. Is there something else I need to do?
Aaron,
What does listgeo report for the generated .tif file? What does the PROJECTION
section of your MAP say? If the projection in your map file is supported
for translation to GeoTIFF format you should get a georeferenced file.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
