[Mapserver-users] Loading data from another server
Jeff L.
nf10 at hotmail.com
Wed Aug 27 15:00:44 EDT 2003
Sorry about that: i meant by storage back end a web server directory where
the data are stored.
Yes the data need to be pulled by an url. Example:
www.myDataServer.com/data
Jeff
>From: "Lowell Filak"<lfilak at medinaco.org>
>To: "Jeff L." <nf10 at hotmail.com>, David.Fawcett at state.mn.us,
>lfilak at medinaco.org, mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] Loading data from another server
>Date: Wed, 27 Aug 2003 14:57:56 -0400
>What type of storage back end is it?
>I'm confused as you mentioned earlier that the data could be pulled
>through a URL.
>Lowell
>The following message was sent by "Jeff L." <nf10 at hotmail.com> on Wed,
>27 Aug 2003 18:50:59 +0000.
> > Hi David,
> > For a start i'm trying to run the demo, but once i have the demo
>running, i
> > would try something more elaborated.
> > The option 2 sounds good by having the WMS. But it's seems that the
>server
> > hosting the data have to run also MapServ. My remote server has no
>business
> > intelligence, only a storage back end for the data.
> > Any example would be more than welcome.
> > Jeff
> > >From: "Fawcett, David" <David.Fawcett at state.mn.us>
> > >To: lfilak at medinaco.org, mapserver-users at lists.gis.umn.edu,
>"'Jeff
> > >L.'" <nf10 at hotmail.com>
> > >Date: Wed, 27 Aug 2003 13:41:06 -0500
> > >As Lowell said below, you have two options:
> > >1. To access the data directly, you have to configure your server(s)
>so
> > >that you can 'see' it as a directory in a path on your machine.
>SHAPEPATH
> > >has to be a valid path (not URL).
> > >I think that the key here is that based on the hardware and software
> > >platform and security scheme you are utilizing, you need to figure
>out how
> > >to map/mount/access a remote drive. This is more a question for your
>admin
> > >than this list.
> > >2. You can set up a WMS server using MapServer, which I haven't
>done, but
> > >I understand isn't that hard. Depending on the data that you need, you
> > >could also potentially hit an existing WMS server that contains the
>data.
> > >Heck, if this is just for a demo, you could possibly put the data on
>a CD
> > >and point your SHAPEPATH to a folder on the CD.
> > >platform you are utilizing, you need to figure out how to
>map/mount/access
> > > > From: Jeff L.[SMTP:nf10 at hotmail.com]
> > > > Sent: Wednesday, August 27, 2003 1:03 PM
> > > > To: lfilak at medinaco.org; mapserver-users at lists.gis.umn.edu
> > > > Subject: Re: [Mapserver-users] Loading data from another server
> > > > Hi,
> > > > I went through the documentation "WMS client and WMS server",
>however
> > >it's
> > > > seems that server location of the data have to have mapserver
>installed.
> > >I
> > > > might be wrong. And also there is no suggestion about replacing the
> > > > "SHAPEPATH".
> > > > My need is to run the demonstration project, but by decoupling the
>data
> > >from
> > > > the application.
> > > > I can run the demo fine if every is installed in the same server.
>Now i
> > > > moved the shape data to another web server and want to be able to
>run
> > >the
> > > > demonstration.
> > > > My understanding is that i would be able to that by making
>modifications
> > >to
> > > > the .map file only. I guess i was wrong.
> > > > If there is any example, how to run the demo (or another project)
>using
> > > > remote data, that would be great.
> > > > Jeff Lacoste
> > > > >To: "Jeff L." <nf10 at hotmail.com>, lfilak at medinaco.org,
> > > > >Date: Wed, 27 Aug 2003 12:47:27 -0400
> > > > >http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapServer
> > > > >http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WFSMapServer
> > > > >HTH
> > > > >Lowell
>Wed,
> > > > >27 Aug 2003 16:11:35 +0000.
> > > > > > Thanks Lowel for your answer. Could you please point me to how
>to do
> > > > >that ?
> > > > > > a document or an url about accessing remote data would be great.
> > > > > > Jeff Lacoste
> > > > > > >Date: Wed, 27 Aug 2003 12:05:50 -0400
> > > > > > >That format for accessing data requires that the data looks
>like a
> > > > >local
> > > > > > >file whether it is network mounted or etc.
> > > > > > >There is also an option of reading data in a WMS or WFS fashion
> > >from a
> > > > > > >remote source.
> > > > > > >HTH
> > > > > > >Lowell
> > >Wed,
> > > > > > >27 Aug 2003 15:12:32 +0000.
> > > > > > > > Hi,
> > > > > > > > I was wondering if the location of data used in MapServer
>can be
> > >a
> > > > > > >different
> > > > > > > > location from the one where MapServer is running.
> > > > > > > > I would like to run the MapServer in a server pointing to
>data
> > >in
> > > > > > >another
> > > > > > > > server. I tried to change this tag in the .map file:
> > > > > > > > SHAPEPATH "http://www.MyServer.com/data/"
> > > > > > > > There was an error:
> > > > > > > > msOpenSHPFile(): Unable to access file. (MyLayerData)
> > > > > > > > My data do exist in the "http://www.MyServer.com/data/"
> > >location.
> > > > > > > > I'm using MapServer 3.6.
> > > > > > > > Thanks,
> > > > > > > > Jeff Lacoste
> > >_________________________________________________________________
> > > > > > > > The new MSN 8: smart spam protection and 2 months FREE*
> > > > > > > > http://join.msn.com/?page=features/junkmail
> > > > > > > > Mapserver-users mailing list
> > > > > > > > Mapserver-users at lists.gis.umn.edu
> > > > > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > MSN 8 with e-mail virus protection service: 2 months FREE*
> > > > http://join.msn.com/?page=features/virus
> > Protect your PC - get McAfee.com VirusScan Online
> > http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
