[Mapserver-users] Linux/Apache security wrt shapefiles data
Daniel Morissette
morissette at dmsolutions.ca
Wed Aug 27 17:00:15 EDT 2003
Did you also make sure that /home/pkishor is at least "r-x" for the
apache user? Every directory in the path that leads to the gisdata
directory has to be at least "r-x" for the apache user.
Daniel
pkishor_98 wrote:
> yes. this is related to MapServer ;-).
> OS: RH9
> MapServer 4.0 config-ed and setup correctly.
> I have my shapefiles under "/home/pkishor/gisdata"
> and the darn Mapserver refuses to open the shapefiles. Error log shows
> msSHPOpenFile(): Unable to access file. (/home/pkishor/gisdata/bio)
> I move the shapefiles to "/var/www/html/gisdata" and everything works
> fine.
> Apache runs as apache:apache, and in both cases I have chown-ed and
> chgrp-ed the gisdata directory to apache:apache, and also chmod-ed it
> to 777 for good measure. Why is Mapserver unable to read gisdata
> stored in my home directory? I am new to Linux/RH9, so be gentle in
> your pedagoguery ;-).
> Many thanks,
> Puneet.
