[Mapserver-users] problem with IMAGEMODE RGBA
Matt Doggett
mdoggett at coas.oregonstate.edu
Wed Aug 27 17:26:27 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000D_01C36CA7.336919D0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
I need to use 24-bit PNG output with transparency so I'm using IMAGEMODE
RGBA. However, with this mode, Mapserver creates an image with a bogus
gray background colors most notably in the legend icons and the labels.
If I turn all the layers off, then the entire map background is gray.
Does anyone know what's going on here? I've attached a JPEG image
showing what this looks like.
Here is a snippet of my .map file:
OUTPUTFORMAT
NAME PNG24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png24"
FORMATOPTION "INTERLACE=ON"
END
IMAGETYPE PNG24
Matt
(RedHat8.0, Apache2.0, Mapserver 4.0, Php4.2.3, gd-2.0.12)
Content-Type: image/jpeg;
name="untitled2.jpg"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="untitled2.jpg"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------=_NextPart_000_000D_01C36CA7.336919D0--
