[Mapserver-users] Oracle 8.1.7 & MapServer HowTo XP/2000
Flavio Hendry
flavio at tydac.ch
Thu Aug 28 08:12:38 EDT 2003
Hi List
First many thanks to Assefa, Daniel and ... Google ...
Daniel Morisette told me to report the way to get the monster running
with XP/2000 and MapServer. No guarantee whatsoever that your computer
won't explode .... ;-) ...
The Oracle part:
A: You will not be able to install Oracle on a PC under Win 2000 or
Win XP - just won't do anything - known bug, do as follows:
1 - Copy your Oracle CD into hard disk in your
machine. For example Copy from oracle8i CD into "C:\tmp\orainst" ...
(on some sites I found not to call this dir "oracle")
2 - Search the two files named Symcjit.dll in the dir where you
have copied Oracle8i. You can found them in (example):
C:\tmp\orainst\stage\Components\oracle.swd.jre\1.1.7.30\1
\DataFiles\Expanded\jre\win32\bin\symcjit.dll
or use search option in the c:\oracle directory to find 2 files
symcjit.dll to
3 - Rename this file (Example): symcjit_back.dll (make sure to find
two files and rename them)
4 - Execute the Oracle setup.exe from C:\Oracle\setup.exe and follow
the instructions ...
B: on Win XP, when rebooting you might get the constantly showing up
ugly error that java.exe crashed. To stop that go into the win admin
toool / services and stop the "Oracle HTTPServer" Service and set it
to manual.
The MapServer Part:
1. Download and install MapServer Oracle Compilation from DM Solutions
(I don't know it DM leaves the files there however, worst case contact
me ...):
mapserver/php_mapscript (php4.3.2) build with Oracle oci
librairies (8.1.7) at http://www2.dmsolutions.ca/tmp/mapserver_ora8.1.7.zip
The zip contains the exe file of mapserver, php_mapscript_40.dll and
oci.dll.
Note that php_mapscript_40.dll is build with links to other libraries
like xerces, pdf, .... So you need to download those dll and install
them. The best approch is to download and install first the zip at
http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-win32-php4.3.2.zip
and then replace the exe and the php_mapscript_40.dll with the new ones.
2. there will be an additional thing to fix in oracle:
Obviously this is a well know feature (bug). After a successfull
installation of Oracle 8.1.7 you have to change
SQLNET.AUTHENTICATION_SERVICE=(NTS)
to
SQLNET.AUTHENTICATION_SERVICE=()
in sqlnet.ora (search for this file in the dir where you installed
Oracle).
3. Map-File, looks i.e. like that:
LAYER
CONNECTION "chur/chur at demo"
CONNECTIONTYPE oraclespatial
DATA "geoloc from Bodenbedeckung using srid 262148"
GROUP "AV"
NAME "Bodenbedeckung"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POLYGON
UNITS METERS
CLASSITEM "ART"
CLASS
NAME "Gebaeude"
EXPRESSION "Gebaeude"
COLOR 255 255 220
OUTLINECOLOR 0 0 0
TEMPLATE ttt.htm
END
END
Some things to be explained:
- chur/chur at demo are userid/password at service
- "geoloc" is the Geometry column Oracle uses (sometimes GEOM or
whatever ...)
- the srid number you'll find in the table called
SDO_GEOM_METADAT_TABLE or in any Table under the register called
"Spatial".
Hope it helps if somebody has to go through the same nightmare ...
Mit freundlichem Gruss / Best regards
Flavio Hendry
++++++++++ Neue Neapoljs Seiten auf www.neapoljs.com +++++++++++
############ Mit freundlichen Gruessen / Kind Regards
############ Flavio Hendry- mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
