[Mapserver-users] mapscript - queryByPoint help, simple Q
poff poff at sixbit.org
Thu Aug 28 09:06:23 EDT 2003
> Do you have a template defined for the layer?
No, sounds like I should!
I have never used templates before, but in the query layer, and the point
class I added:
TEMPLATE "dummy"
And instead of No Records I get:
Warning: MapServer Error in msOpenSHPFile(): No (NULL) filename provided
So it seems like progress!
$result=$uLayer->queryByPoint ($my_point,MS_SINGLE,-10);
Generates this error, but I didn't think I'd need a SHP file or anything.
Any ideas how to proceed?
Thanks very much!
P
> Lowell
> The following message was sent by poff <poff at sixbit.org> on Thu, 28 Aug
> 2003 09:54:37 +0200.
> > Hello again,
> > I'm having problems getting any results with queryByPoint.
> > Basically I draw my map as usual then I try the following on the drawn
> > layer:
> >         $my_point = ms_newpointObj();
> >         $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
> >         $result=$uLayer->queryByPoint ($my_point,MS_SINGLE,-20);
> > I tried different buffers, zooming in etc. but I always get: "No matching
> > Record(s) found"
> > The layer is drawn OK, and is simple as far as the mapfile goes (nothing
> > apart from):
> > STATUS ON
> > TYPE POINT
> > LABELCACHE FALSE
> > CLASS
> > 	SYMBOL
> > END
> > END
> > The points are drawn in from a database, so if I could convert the
> > $_REQUEST clicks into lat/lon I could just query the database instead of
> > mapserver.
> > Has anyone got any light to shed on this? I'd be most grateful if someone
> > could show me what I'm doing wrong, or suggest how to get the lat/long
> > values. The archives didn't seem to have anyone in my situation - which
> > suggested to me I'm missing something basic out.
> > Thanks in advance,
> > poff at sixbit.org
> > SDF Public Access UNIX System - http://sdf.lonestar.org
> > Please do not carbon copy replies to me
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
poff at sixbit.org
