[Mapserver-users] ArcExplorer 4.0.1 as a MapServer WMS client
Paul Ramsey
pramsey at refractions.net
Thu Aug 28 11:31:55 EDT 2003
Brutal!
One thing I note though is that your document does not have an XML
header, which would ordinarily feed the parser the expected character
set. Perhaps in the absence of a header, it is assuming a very simple
character set?
Paul
Brent Fraser wrote:
> I did some editing of your xml/gml trying to get ArcExplorer to recognize
> it. The message window kept reporting the version as none, even though the
> version number seemed ok to me. So I tried tip 2 above and IE pointed to
> several parsing errors. Apparently ArcExplorer (and IE) will not allow
> non-ASCII characters anywhere in the document.
> When I changed Rincão to Rincao and Talhões to Talhoes, ArcExplorer worked
> with it.
<WMT_MS_Capabilities version="1.1.1" updateSequence="0">
<!-- MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
