[Mapserver-users] problem with IMAGEMODE RGBA
    Matt Doggett
    mdoggett at coas.oregonstate.edu
    Thu Aug 28 14:30:15 PDT 2003
No.  I can setting IMAGECOLOR has no impact on the resulting gray shaded
areas.  I've found a couple more tidbits:
* Changing OUTPUTFORMAT to 24-bit JPEG solves the problem
* Changing label TYPE from TRUETYPE to BITMAP solves the problem with
the bogus gray boxes around the labels (though it does nothing for the
grayshade in the legend icons).
Soooo, the problem appears to be pointing to the 24-bit transparency and
PNG images.
md
-----Original Message-----
Sent: Thursday, August 28, 2003 5:51 AM
To: Matt Doggett; 'Mapserver List'
Subject: Re: [Mapserver-users] problem with IMAGEMODE RGBA
I haven't used 24-bit color yet, but does it have to do with the
specified map IMAGECOLOR?
Lowell
The following message was sent by "Matt Doggett"
<mdoggett at coas.oregonstate.edu> on Wed, 27 Aug 2003 14:26:27 -0700.
> I need to use 24-bit PNG output with transparency so I'm using
IMAGEMODE
> RGBA.  However, with this mode, Mapserver creates an image with a
bogus
> gray background colors most notably in the legend icons and the
labels.
> If I turn all the layers off, then the entire map background is gray.
> Does anyone know what's going on here? I've attached a JPEG image
> showing what this looks like.
> Here is a snippet of my .map file:
>   OUTPUTFORMAT
>     NAME PNG24
>     DRIVER "GD/PNG"
>     MIMETYPE "image/png"
>     IMAGEMODE RGBA
>     EXTENSION "png24"
>     FORMATOPTION "INTERLACE=ON"
>   END
>   IMAGETYPE PNG24
> Matt
> (RedHat8.0, Apache2.0, Mapserver 4.0, Php4.2.3, gd-2.0.12)
More information about the MapServer-users
