[Mapserver-users] Re: querybyattributes with Postgres/Postgis Layer
Damian Schroder map_surfer at yahoo.com
Mon Dec 1 15:09:47 EST 2003
--0-735338114-1070309387=:61657
Content-Type: text/plain; charset=us-ascii
You should try using a filter with querybyrect. here is an example:
$oRect = $oMap->extent;//or set it to your map's max extents
$oLayer = $oMap->getLayerbyName("yourlayername");
$filter = "\"query ="."'".$yourattributename."'\"";
$oLayer->setFilter($filter);
if ($oLayer->queryByrect($oRect) == MS_SUCCESS){
whatever you want to code here
Nicol Hermann <mapserver at geochem.de> wrote:
Hi Colin,
thank you very much for your answer.
I'am not sure if i understood your tip correct.
I modified my code to:
$layer = $Map ->getLayerbyname("Regionen");
$layer -> set("status", MS_ON );
$cobj = $layer -> getclass(0);
$cobj -> set ("template", "postgis_query_attribut.php");
$status = $layer->querybyattributes("plzort01", "Mutterstadt",
MS_MULTIPLE);
The url/filename of my template is the name of the script itself. Is
this right?
When i execute my script with the 'getclass(0)' request the Message:
"Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE
..." disappeared and i get back a blank page. If i comment out the line
with this request the message appears again.
I both cases i futher on get the Message:
ERROR: Attribute "mutterstadt" not found
on my shell whenever i reload my script.
According to the documentation "mutterstadt" is the 'qstring' of the
method an not the 'qitem' (->
int queryByAttributes(string qitem, string qstring, int mode) )
Futher hints would be greatly appreciated.
Many thanks
Nicol
Am Mo, 2003-12-01 um 15.25 schrieb cgowens at softhome.net:
> Try using the TEMPLATE option under CLASS for the LAYER. Set the the url to
> your query.php file that runs the SQL statement.
> Colin
> mapserver-users-request at lists.gis.umn.edu writes:
> > Send Mapserver-users mailing list submissions to
> > mapserver-users at lists.gis.umn.edu
> > To subscribe or unsubscribe via the World Wide Web, visit
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> > mapserver-users-admin at lists.gis.umn.edu
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of Mapserver-users digest..."
> > Today's Topics:
> > 1. Problems with tab files in MapLab (Stephen Wallace)
> > 2. Re: [ms4w-users] Problems with tab files in MapLab (Daniel Morissette)
> > 3. MapServer passes 82/83 tests of the OGC WMS testsuite (Daniel Morissette)
> > 4. Re: MapServer passes 82/83 tests of the OGC WMS testsuite (Daniel Morissette)
> > 5. Re: Re: MapServer passes 82/83 tests of the OGC
> > WMS testsuite (Doug Cates)
> > 6. RE: MapServer passes 82/83 tests of the OGC WMS
> > testsuite (Kralidis,Tom [Burlington])
> > 7. Re: Re: MapServer passes 82/83 tests of the OGC
> > WMS testsuite (Gerry Creager N5JXS)
> > 8. Re: MapServer passes 82/83 tests of the OGC WMS testsuite (Bart van den Eijnden)
> > 9. Re: querybyattributes with Postgres/Postgis Layer (Damian Schroder)
> > 10. Segmentation Fault -- reference image -- PHP (Ed Martin)
> > --__--__--
> > Message: 9
> > Date: Sat, 29 Nov 2003 08:41:48 -0800 (PST)
> > From: Damian Schroder
> > Subject: Re: [Mapserver-users] querybyattributes with Postgres/Postgis Layer
> > To: mapserver-users at lists.gis.umn.edu
> > --0-1435250590-1070124108=:89418
> > try using a filter instead of querybyattributes.
> > Nicol Hermann wrote:Dear List,
> > i trying to do a querybyattributes Query with a Postgres/Postgis layer
> > and get the following error:
> > (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> > plzort01::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from plz_gebiete WHERE (Mutterstadt) and (the_geom && setSRID( 'BOX3D(5.865627 46.57242768,15.039879 55.75900832)'::BOX3D,find_srid('','plz_gebiete','the_geom') ))'
> > here is the relevant part of my code:
> > MS_MULTIPLE);
> > It seems that the 'qitem' (plzort01) won't be evaluated because it is
> > not present in the SQL statement.
> > I also tried the qitem with upper case. The same error appears.
> > The debugging message on my shell says:
> > My Postgis Version is: Mappostgis.c - version of June 12/2003.
> > and i`am using Mapserver 4.0.1 on a Linux box.
> > Does anybody know how I can solve this problem?
> > Many thanks
> > Nicol
> > Nicol Hermann
> > Mapserver-users at lists.gis.umn.edu
> > Do you Yahoo!?
> > Free Pop-Up Blocker - Get it now
> > Content-Type: text/html; charset=us-ascii
> > Dear List,
MS_MULTIPLE);
I also tried t!
he!
> q!
> > item with
Many thanks
Nicol
Nicol Hermann
> > Do you Yahoo!?
> > --0-1435250590-1070124108=:89418--
> > --__--__--
> > Message: 10
> > Date: Sat, 29 Nov 2003 11:59:53 -0500
> > From: Ed Martin
> > Subject: [Mapserver-users] Segmentation Fault -- reference image -- PHP
> > i am using the map file and map stuff from the cvs mapserver (did not
> > compile from cvs, i used the stable version 4.0.1) and when i try to
> > get the reference image using a very simple script i get the jpeg
> > header an then a segmentation fault when run in the command line and a
> > blank page when in a browser, turning off the jpeg header still gives
> > me a blank page
> > here is the php file i am using
> > > > require_once('../inc/conf.inc.php');//get config
> > //load mapscript
> > dl("php_mapscript.so");
> > header("Content-type: image/jpeg");
> > // start map
> > $map=ms_newMapObj("tests/test.map");
> > $img=$map->drawReferenceMap();
> > $img->saveImage('');
> > and here is the reference part of the map file
> > #refence map
> > REFERENCE
> > IMAGE ./reference.jpeg
> > EXTENT -0.5 50.977222 0.5 51.977222
> > SIZE 120 120
> > STATUS ON
> > COLOR 255 255 0
> > OUTLINECOLOR 255 100 0
> > STATUS ON
> > MARKER "line"
> > MARKERSIZE 5
> > MINBOXSIZE 50
> > MINBOXSIZE 100
> > END
> > i have output set to jpeg and changing the reference image to jpg or
> > png doesn't help and i tried gif and that gave an error saying that it
> > couldn't load it (probably because gifs aren't supported by gd, but
> > this page (
> > http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#referencemap
> > ) says it has to be a gif)
> > could it be the way i made the reference image, i just took the main
> > image, cropped out the boarder, shrunk it to 120x120 and saved it in
> > various formats
> > i see nothing in my apache logs, but i know it is logging to them
> > because a parse error will show up, i have error reporting set to the
> > highest (E_ALL), i'm using mapserver 4.0.1, php 4.3.4 as CGI, apache
> > 2.0.48, slackware linux 9.0
> > so does anyone have any clue as to what is causing this, my map file,
> > do i have to put more stuff in the php file, is it the way i made the
> > image, or is it a bug
> > --__--__--
> > End of Mapserver-users Digest
Nicol Hermann
Do you Yahoo!?
<DIV>You should try using a filter with querybyrect. here is an example:</DIV>
<DIV><FONT size=2>
<P>$oRect = $oMap-&gt;extent;//or set it to your map's max extents</P>
<P>$oLayer = $oMap-&gt;getLayerbyName("yourlayername");</P>
<P>$filter = "\"query ="."'".$yourattributename."'\"";</P>
<P>$oLayer-&gt;setFilter($filter);</P>
<P>if ($oLayer-&gt;queryByrect($oRect) == MS_SUCCESS){</P>
<P>whatever you want to code here</P></FONT>}<BR><BR><B><I>Nicol Hermann &lt;mapserver at geochem.de&gt;</I></B> wrote:</DIV>
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">Hi Colin,<BR><BR>thank you very much for your answer.<BR>I'am not sure if i understood your tip correct.<BR><BR>I modified my code to:<BR><BR>$layer = $Map -&gt;getLayerbyname("Regionen");<BR>$layer -&gt; set("status", MS_ON );<BR>$cobj = $layer -&gt; getclass(0);<BR>$cobj -&gt; set ("template", "postgis_query_attribut.php");<BR>$status = $layer-&gt;querybyattributes("plzort01", "Mutterstadt",<BR>MS_MULTIPLE);<BR><BR>The url/filename of my template is the name of the script itself. Is<BR>this right?<BR><BR>When i execute my script with the 'getclass(0)' request the Message: <BR>"Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE<BR>..." disappeared and i get back a blank page. If i comment out the line<BR>with this request the message appears again. <BR><BR>I both cases i futher on get the Message:<BR>ERROR: Attribute "mutterstadt" not found<BR>on my shell whenever
 i reload my script.<BR><BR>According to the documentation "mutterstadt" is the 'qstring' of the<BR>method an not the 'qitem' (-&gt;<BR>int queryByAttributes(string qitem, string qstring, int mode) )<BR><BR>Futher hints would be greatly appreciated.<BR>Many thanks<BR>Nicol<BR><BR><BR>Am Mo, 2003-12-01 um 15.25 schrieb cgowens at softhome.net:<BR>&gt; Try using the TEMPLATE option under CLASS for the LAYER. Set the the url to <BR>&gt; your query.php file that runs the SQL statement. <BR>&gt; <BR>&gt; Colin <BR>&gt; <BR>&gt; <BR>&gt; mapserver-users-request at lists.gis.umn.edu writes: <BR>&gt; <BR>&gt; &gt; Send Mapserver-users mailing list submissions to<BR>&gt; &gt; mapserver-users at lists.gis.umn.edu <BR>&gt; &gt; <BR>&gt; &gt; To subscribe or unsubscribe via the World Wide Web, visit<BR>&gt; &gt; http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<BR>&gt; &gt; or, via email, send a message with subject or body 'help' to<BR>&gt; &gt; mapserver-users-request at lists.gis.umn.edu <BR>&gt;
 &gt; <BR>&gt; &gt; You can reach the person managing the list at<BR>&gt; &gt; mapserver-users-admin at lists.gis.umn.edu <BR>&gt; &gt; <BR>&gt; &gt; When replying, please edit your Subject line so it is more specific<BR>&gt; &gt; than "Re: Contents of Mapserver-users digest..." <BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; Today's Topics: <BR>&gt; &gt; <BR>&gt; &gt; 1. Problems with tab files in MapLab (Stephen Wallace)<BR>&gt; &gt; 2. Re: [ms4w-users] Problems with tab files in MapLab (Daniel Morissette)<BR>&gt; &gt; 3. MapServer passes 82/83 tests of the OGC WMS testsuite (Daniel Morissette)<BR>&gt; &gt; 4. Re: MapServer passes 82/83 tests of the OGC WMS testsuite (Daniel Morissette)<BR>&gt; &gt; 5. Re: Re: MapServer passes 82/83 tests of the OGC<BR>&gt; &gt; WMS testsuite (Doug Cates)<BR>&gt; &gt; 6. RE: MapServer passes 82/83 tests of the OGC WMS<BR>&gt; &gt; testsuite (Kralidis,Tom [Burlington])<BR>&gt; &gt; 7. Re: Re: MapServer passes 82/83 tests of the OGC<BR>&gt; &gt; WMS testsuite
 (Gerry Creager N5JXS)<BR>&gt; &gt; 8. Re: MapServer passes 82/83 tests of the OGC WMS testsuite (Bart van den Eijnden)<BR>&gt; &gt; 9. Re: querybyattributes with Postgres/Postgis Layer (Damian Schroder)<BR>&gt; &gt; 10. Segmentation Fault -- reference image -- PHP (Ed Martin) <BR>&gt; &gt; <BR>&gt; &gt; --__--__--<BR>&gt; <BR>&gt; &gt; <BR>&gt; &gt; Message: 9<BR>&gt; &gt; Date: Sat, 29 Nov 2003 08:41:48 -0800 (PST)<BR>&gt; &gt; From: Damian Schroder <MAP_SURFER at YAHOO.COM><BR>&gt; &gt; Subject: Re: [Mapserver-users] querybyattributes with Postgres/Postgis Layer<BR>&gt; &gt; To: mapserver-users at lists.gis.umn.edu <BR>&gt; &gt; <BR>&gt; &gt; --0-1435250590-1070124108=:89418<BR>&gt; &gt; Content-Type: text/plain; charset=us-ascii <BR>&gt; &gt; <BR>&gt; &gt; try using a filter instead of querybyattributes. <BR>&gt; &gt; <BR>&gt; &gt; Nicol Hermann <MAPSERVER at GEOCHEM.DE>wrote:Dear List, <BR>&gt; &gt; <BR>&gt; &gt; i trying to do a querybyattributes Query with a Postgres/Postgis
 layer<BR>&gt; &gt; and get the following error: <BR>&gt; &gt; <BR>&gt; &gt; Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE<BR>&gt; &gt; (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT<BR>&gt; &gt; plzort01::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from plz_gebiete WHERE (Mutterstadt) and (the_geom &amp;&amp; setSRID( 'BOX3D(5.865627 46.57242768,15.039879 55.75900832)'::BOX3D,find_srid('','plz_gebiete','the_geom') ))' <BR>&gt; &gt; <BR>&gt; &gt; here is the relevant part of my code: <BR>&gt; &gt; <BR>&gt; &gt; $layer = $Map -&gt;getLayerbyname("Regionen");<BR>&gt; &gt; $layer -&gt; set("status", MS_ON );<BR>&gt; &gt; $status = $layer-&gt;querybyattributes("plzort01", "Mutterstadt",<BR>&gt; &gt; MS_MULTIPLE); <BR>&gt; &gt; <BR>&gt; &gt; It seems that the 'qitem' (plzort01) won't be evaluated because it is<BR>&gt; &gt; not present in the SQL statement.<BR>&gt; &gt; I also tried the qitem with upper case. The
 same error appears. <BR>&gt; &gt; <BR>&gt; &gt; The debugging message on my shell says: <BR>&gt; &gt; ERROR: Attribute "mutterstadt" not found <BR>&gt; &gt; <BR>&gt; &gt; My Postgis Version is: Mappostgis.c - version of June 12/2003. <BR>&gt; &gt; and i`am using Mapserver 4.0.1 on a Linux box. <BR>&gt; &gt; <BR>&gt; &gt; Does anybody know how I can solve this problem?<BR>&gt; &gt; Many thanks<BR>&gt; &gt; Nicol <BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; -- <BR>&gt; &gt; Nicol Hermann <BR>&gt; &gt; <BR>&gt; &gt; _______________________________________________<BR>&gt; &gt; Mapserver-users mailing list<BR>&gt; &gt; Mapserver-users at lists.gis.umn.edu<BR>&gt; &gt; http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; ---------------------------------<BR>&gt; &gt; Do you Yahoo!?<BR>&gt; &gt; Free Pop-Up Blocker - Get it now<BR>&gt; &gt; --0-1435250590-1070124108=:89418<BR>&gt; &gt; Content-Type: text/html; charset=us-ascii <BR>&gt; &gt; <BR>&gt;
 &gt;
<DIV>try using&nbsp;a filter instead of querybyattributes.<BR><BR><B><I>Nicol Hermann &lt;mapserver at geochem.de&gt;</I></B> wrote:<BR>&gt; &gt;
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">Dear List,<BR><BR>i trying to do a querybyattributes Query with a Postgres/Postgis layer<BR>and get the following error:<BR><BR>Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE<BR>(the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT<BR>plzort01::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from plz_gebiete WHERE (Mutterstadt) and (the_geom &amp;&amp; setSRID( 'BOX3D(5.865627 46.57242768,15.039879 55.75900832)'::BOX3D,find_srid('','plz_gebiete','the_geom') ))'<BR><BR>here is the relevant part of my code:<BR><BR>$layer = $Map -&gt;getLayerbyname("Regionen");<BR>$layer -&gt; set("status", MS_ON );<BR>$status = $layer-&gt;querybyattributes("plzort01", "Mutterstadt",<BR>MS_MULTIPLE);<BR><BR>It seems that the 'qitem' (plzort01) won't be evaluated because it is<BR>not present in the SQL statement.<BR>I also tried
 t!<BR>he!<BR>&gt; q!<BR>&gt; &gt; item with<BR>&gt; &gt; upper case. The same error appears.<BR><BR>The debugging message on my shell says: <BR>ERROR: Attribute "mutterstadt" not found<BR><BR>My Postgis Version is: Mappostgis.c - version of June 12/2003. <BR>and i`am using Mapserver 4.0.1 on a Linux box.<BR><BR>Does anybody know how I can solve this problem?<BR>Many thanks<BR>Nicol<BR><BR><BR>-- <BR>Nicol Hermann <MAPSERVER at GEOCHEM.DE><BR><BR>_______________________________________________<BR>Mapserver-users mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</BLOCKQUOTE></DIV>
<P>
<HR SIZE=1>
<BR>&gt; &gt; Do you Yahoo!?<BR><BR>&gt; &gt; <A href="http://us.rd.yahoo.com/slv/mailtag/*http://companion.yahoo.com/">Free Pop-Up Blocker - Get it now</A><BR>&gt; &gt; --0-1435250590-1070124108=:89418-- <BR>&gt; &gt; <BR>&gt; &gt; --__--__-- <BR>&gt; &gt; <BR>&gt; &gt; Message: 10<BR>&gt; &gt; Date: Sat, 29 Nov 2003 11:59:53 -0500<BR>&gt; &gt; From: Ed Martin <EDMAN007X at MAC.COM><BR>&gt; &gt; To: mapserver-users at lists.gis.umn.edu<BR>&gt; &gt; Subject: [Mapserver-users] Segmentation Fault -- reference image -- PHP <BR>&gt; &gt; <BR>&gt; &gt; i am using the map file and map stuff from the cvs mapserver (did not <BR>&gt; &gt; compile from cvs, i used the stable version 4.0.1) and when i try to <BR>&gt; &gt; get the reference image using a very simple script i get the jpeg <BR>&gt; &gt; header an then a segmentation fault when run in the command line and a <BR>&gt; &gt; blank page when in a browser, turning off the jpeg header still gives <BR>&gt; &gt; me a blank page <BR>&gt; &gt;
 <BR>&gt; &gt; here is the php file i am using <BR>&gt; &gt; <BR>&gt; &gt; <?<br>&gt; &gt; require_once('../inc/conf.inc.php');//get config<BR>&gt; &gt; //load mapscript<BR>&gt; &gt; dl("php_mapscript.so");<BR>&gt; &gt; header("Content-type: image/jpeg");<BR>&gt; &gt; // start map<BR>&gt; &gt; $map=ms_newMapObj("tests/test.map");<BR>&gt; &gt; $img=$map-&gt;drawReferenceMap();<BR>&gt; &gt; $img-&gt;saveImage('');<BR>&gt; &gt; ?&gt; <BR>&gt; &gt; <BR>&gt; &gt; and here is the reference part of the map file <BR>&gt; &gt; <BR>&gt; &gt; #refence map<BR>&gt; &gt; REFERENCE<BR>&gt; &gt; IMAGE ./reference.jpeg<BR>&gt; &gt; EXTENT -0.5 50.977222 0.5 51.977222<BR>&gt; &gt; SIZE 120 120<BR>&gt; &gt; STATUS ON<BR>&gt; &gt; COLOR 255 255 0<BR>&gt; &gt; OUTLINECOLOR 255 100 0<BR>&gt; &gt; STATUS ON<BR>&gt; &gt; MARKER "line"<BR>&gt; &gt; MARKERSIZE 5<BR>&gt; &gt; MINBOXSIZE 50<BR>&gt; &gt; MINBOXSIZE 100<BR>&gt; &gt; END <BR>&gt; &gt; <BR>&gt; &gt; i have output set to jpeg and changing the
 reference image to jpg or <BR>&gt; &gt; png doesn't help and i tried gif and that gave an error saying that it <BR>&gt; &gt; couldn't load it (probably because gifs aren't supported by gd, but <BR>&gt; &gt; this page ( <BR>&gt; &gt; http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#referencemap<BR>&gt; &gt; ) says it has to be a gif) <BR>&gt; &gt; <BR>&gt; &gt; could it be the way i made the reference image, i just took the main <BR>&gt; &gt; image, cropped out the boarder, shrunk it to 120x120 and saved it in <BR>&gt; &gt; various formats <BR>&gt; &gt; <BR>&gt; &gt; i see nothing in my apache logs, but i know it is logging to them <BR>&gt; &gt; because a parse error will show up, i have error reporting set to the <BR>&gt; &gt; highest (E_ALL), i'm using mapserver 4.0.1, php 4.3.4 as CGI, apache <BR>&gt; &gt; 2.0.48, slackware linux 9.0 <BR>&gt; &gt; <BR>&gt; &gt; so does anyone have any clue as to what is causing this, my map file, <BR>&gt; &gt; do i have to put more stuff
 in the php file, is it the way i made the <BR>&gt; &gt; image, or is it a bug <BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; --__--__-- <BR>&gt; &gt; <BR>&gt; &gt; _______________________________________________<BR>&gt; &gt; Mapserver-users mailing list<BR>&gt; &gt; Mapserver-users at lists.gis.umn.edu<BR>&gt; &gt; http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<BR>&gt; &gt; <BR>&gt; &gt; <BR>&gt; &gt; End of Mapserver-users Digest<BR>&gt; <BR>&gt; _______________________________________________<BR>&gt; Mapserver-users mailing list<BR>&gt; Mapserver-users at lists.gis.umn.edu<BR>&gt; http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<BR>-- <BR>Nicol Hermann <MAPSERVER at GEOCHEM.DE><BR><BR>_______________________________________________<BR>Mapserver-users mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</BLOCKQUOTE><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://us.rd.yahoo.com/slv/mailtag/*http://companion.yahoo.com/">Free Pop-Up Blocker - Get it now</a>
--0-735338114-1070309387=:61657--
