[Mapserver-users] SVG Output
Steve Lime steve.lime at dnr.state.mn.us
Mon Dec 1 16:00:55 EST 2003
Here's an example link that shows SVG MapServer output:
http://maps.dnr.state.mn.us/cgi-bin/mapserv40?map=/usr/local/www/docs/testing/svg/test.map&mode=itemnquery&qitem=cty_name&qstring=/./&qlayer=county
It's super simple, and just dumps MN counties to a SVG document.
There's a smile animation (provided by a student over at the UMN) that
you see when move your mouse over an individual county. The mapfile and
templates can be found at:
  http://maps.dnr.state.mn.us/testing/svg/svg_simple.zip
Note that you'll need the CVS version of MapServer for this stuff to
work. I've tried the above URL with Mozilla (native SVG support,
animation doesn't work) and IE (Adobe plugin) with success.
Please pass along questions or comments!
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Keith Campbell <scoota at supanet.com> 11/25/2003 5:49:16 PM >>>
Thanks Steve, this is helpful.
Keith
Steve Lime wrote:
>There are 2 new additions:
>  - In query templates there is a new tag called shpxy. It allows for
>ad hoc access to the coordinates for any returned shape. There are a
>bunch of tag attributes that allow you to structure the output in a
>variety of ways. I'll have to check the source and post a summary of
>those. In practice you could then setup a query template that looked
>like:
><path id="[shpidx]" d="M [shpxy] ">
>  ... more svg stuff if necessary ...
></path>
>and then build up a svg document with the addition of headers and
>footers.
> - In the map file you can now set an arbitrary MIME-TYPE for query
>output using a web object parameter called QUERYFORMAT. So, for
example
>you might do:
>  QUERYFORMAT "image/svg+xml"
>I'm not real happy with this mechanism, I'd rather use OUTPUTFORMAT
>blocks, but for now this works just fine.
>4.1 will be released as 4.2 after the first of the year. Don't know
>exactly when. The CVS code is VERY stable so I'd be interested in
>feedback.
>Steve
>>>>Keith Campbell <scoota at supanet.com> 11/24/2003 3:02:30 PM >>>
>Steve,
>Thanks for your reply.
>Is there any more information available on these new features? Any
idea
>on when 4.1 is available?
>Keith
>Steve Lime wrote:
>>The 4.1 version has a few new features that should allow the
creation
>of
>>SVG using traditional query templates. There are new capabilities to
>>change output MIME types and to extract feature coordinates into
>>templates. Because SVG is text-based this may work quite well.
>>Steve
>>Stephen Lime
>>Minnesota DNR
>>500 Lafayette Road
>>St. Paul, MN 55155
>>651-297-2937
>>>>>Keith Campbell <scoota at supanet.com> 11/17/2003 5:45:01 PM >>>
>>Just trying to find out what MapServer will do:-
>>In addition to rendering images to the client, it will output GML
>>(through the WFS support) and also SWF (MING) but not SVG - is this
>>correct? Any likelihood of SVG in future?
>>Thanks,
>>Keith
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
