[Mapserver-users] problem with Layer on-fly with MapServer 4
Andrés Collao collao_andres at hotmail.com
Mon Dec 8 10:29:37 EST 2003
this is correct!!!
and I replace the constant , but without results, the problem persist.
I try with numbers (0,1,2,3,4,5,6) , with the same result.
thanks
::: Andrés Collao Pérez :::
[ collao_andres at hotmail.com ]
[ andres at mapserver.cl ]
:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.
:::Il peggior nemico del succeso è la pauta del fallimiento
:::El peor enemigo del éxito es el miedo al fracaso
this
----Original Message Follows----
From: Daniel Morissette <morissette at dmsolutions.ca>
To: Andrés Collao <collao_andres at hotmail.com>
CC: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] problem with Layer on-fly with MapServer 4
Date: Mon, 08 Dec 2003 10:25:25 -0500
Andrés Collao wrote:
>thank you, right now, i know the problem
>the mapfile don´t have de following porperties:
>color
>connectiontype
>size
>(these are the properties that I could prove)
>when i try use STYLE object this don't work , why? i don't know, but
>reading the /tmp/test.map i see I could observe that the properties for
>color, size were not written this also happen to CONNECTIONTYPE, when
>trying to form it dynamically, simply do not make
About the POSTGIS problem, your code contained the line:
   $layer_tmp->set('connectiontype',POSTGIS);
The constant for connection type POSTGIS is MS_POSTGIS and not POSTGIS.
Daniel
  Daniel Morissette               morissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
_________________________________________________________________
MSN Amor: busca tu ½ naranja http://latam.msn.com/amor/
