[Mapserver-users] .TAB files
Martin Kiuru Martin.Kiuru at Elion.ee
Tue Dec 9 04:10:48 EST 2003
Greetings,
I have a trouble with TAB-files in MapLab 2.1-rc3. I have a map-file
which uses 2 shapefiles and works fine. But when I am trying to add TAB
file connected to TIFF file, which covers small part of the big map,
browser MapBrowser window shows nothing, and there is no ROSA controls
in the window. I tryed to add TAB via MapLab interface, after that tryed
to add it manually using this sample :
LAYER
NAME "Builtup_Areas_tab"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "data/tab/092b06_builtup_a.tab"
STATUS ON
CLASS
END
END
But there it doesn't work. I also tried to build the mapfile with only
one layer, which uses TAB but without any effect. During various
experiments with Extent, ROSA application starts (sometimes), but I
never saw my tiff image in MapBrowser or application window. Please,
give me some good advices.
Here is configuration of my mapfile and .tab file.
MAP
  NAME "EESTI"
  STATUS ON
  EXTENT 352772 6360880.68 750300 6658590.32
  SIZE 600 450
  SHAPEPATH "C:/ms4w/Apache/htdocs/maplab/tutorial/data"
  SYMBOLSET "C:/ms4w/Apache/htdocs/maplab/tutorial/etc/symbols.sym"
  FONTSET "C:/ms4w/Apache/htdocs/maplab/tutorial/etc/fonts.txt"
  IMAGETYPE png
  IMAGECOLOR 255 255 255
  UNITS METERS
  WEB
    MINSCALE 1000
    MAXSCALE 5e+007
    IMAGEPATH "C:/ms4w/Apache/htdocs/maplab/tmp/img/"
    IMAGEURL "/maplab/tmp/img/"
  END
  QUERYMAP
    STATUS OFF
    SIZE -1 -1
    COLOR 255 0 0
    STYLE HILITE
  END
  LEGEND
    STATUS ON
    OUTLINECOLOR 255 255 255
    POSITION LL
    KEYSIZE 18 12
    KEYSPACING 5 5
    TEMPLATE
"C:/ms4w/Apache/htdocs/maplab/htdocs/mapbrowser/legend_template.html"
    LABEL
      TYPE BITMAP
      SIZE TINY
      OFFSET 0 0
      BUFFER 0
      MINDISTANCE -1
      MINFEATURESIZE -1
      COLOR 0 0 89
      BACKGROUNDCOLOR 255 255 255
      PARTIALS TRUE
      FORCE FALSE
    END
  END
  SCALEBAR
    STATUS ON
    COLOR 255 255 255
    OUTLINECOLOR 0 0 0
    BACKGROUNDCOLOR 0 0 0
    UNITS KILOMETERS
    INTERVALS 5
    SIZE 150 5
    STYLE 0
    POSITION LL
    LABEL
      TYPE BITMAP
      SIZE SMALL
      OFFSET 0 0
      BUFFER 0
      MINDISTANCE -1
      MINFEATURESIZE -1
      COLOR 0 0 0
      PARTIALS TRUE
      FORCE FALSE
    END
  END
  OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/png"
    DRIVER "GD/PNG"
    EXTENSION "png"
    IMAGEMODE PC256
    TRANSPARENT FALSE
  END
 LAYER
        NAME "Raster"
        TYPE POLYGON
        CONNECTIONTYPE OGR
        CONNECTION
"C:/ms4w/Apache/htdocs/maplab/tutorial/data/44_75_E.TAB"
        STATUS ON
        CLASS
          NAME"Raster"
	    COLOR 250 175 25
          OUTLINECOLOR 255 0 0
        END
     END
END
------------TAB-FILE-------------
!table
!version 300
!charset WindowsLatin1
Definition Table
  File "44_75.TIF"
  Type "RASTER"
  (650000.00,6380001.69) (0,0) Label "Pt 1",
  (660000.00,6380001.69) (5904,0) Label "Pt 2",
  (650000.00,6370000.00) (0,5905) Label "Pt 3",
  (660000.00,6370000.00) (5904,5905) Label "Pt 4"
  CoordSys Earth Projection 3, 33, "m", 24, 57.51755393056, 58,
59.33333333, 500000, 6375000
  Units "m"
