[Mapserver-users] Storing database connections in a CGI session
Bart van den Eijnden bartvde at xs4all.nl
Tue Dec 9 13:45:33 EST 2003
Hi Richard,
what is the absolute difference in performance (time) between Mapserver en
ArcIMS? And can you tell some more about how you did the tests (number of
concurrent users, which tool etc.)?
I think the difference is not only in the database connection, but also in
the caching of data. Although I do not know how ArcIMS works exactly
behind the scenes ofcourse.
An alternative to CGI sessions is the fastcgi approach. Frank Warmerdam
did some work on this a few months ago, but I don't know if there any
useable results.
See also:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?FastCGI
Best regards,
Bart
On Tue, 9 Dec 2003 19:29:32 +0100, Richard Holzmeier
<Richard.Holzmeier at epost.de> wrote:
> Currently i am testing MapServers load performance against ArcIMS using
> SDE
> and OracleSpatial database connections. ArcIMS displaces MapServer with a
> performance rate up to 7:1, certainly due to the overhead of creating a
> new
> session with every request. I´m thinking about using CGI sessions to
> store
> opened database sessions for a while using a library such as CGI::SESSION
> (http://search.cpan.org/~sherzodr/). Unfortunately i´m fairly new with
> C/C++
> and Perl and have no idea of the complexity or possibility to implement
> this.
> If anybody has, i will appreciate responses of any kind. Thanks in
> advance,
> Richard
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
